Ir para o conteúdo principal
Nokia XL Dual Sim Front Camera Replacement
O que você precisa
  1. Nokia XL Dual Sim Front Camera Replacement, Back Cover Removal: passo 1, imagem 1 %32
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
  2. Nokia XL Dual Sim Front Camera Replacement, Battery Removal: passo 2, imagem 1 %32 Nokia XL Dual Sim Front Camera Replacement, Battery Removal: passo 2, imagem 2 %32
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
  3. Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 1: passo 3, imagem 1 %32 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 1: passo 3, imagem 2 %32
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
  4. Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: passo 4, imagem 1 %32 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: passo 4, imagem 2 %32 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: passo 4, imagem 3 %32
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
  5. Nokia XL Dual Sim Front Camera Replacement, System components: passo 5, imagem 1 %32
    • Once the device is open, take note of all the components.
  6. Nokia XL Dual Sim Front Camera Replacement, Camera Removal: passo 6, imagem 1 %32 Nokia XL Dual Sim Front Camera Replacement, Camera Removal: passo 6, imagem 2 %32 Nokia XL Dual Sim Front Camera Replacement, Camera Removal: passo 6, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • With Tweezers, gently unsnap the front camera motherboard connector.
    • The front camera component can now be gently removed.
Conclusão
6 outras pessoas executaram este guia.
Shadeed Bilal
Membro desde: 09/25/14
231 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-4, Brown Fall 2014 Membro de USF Tampa, Team 1-4, Brown Fall 2014
USFT-BROWN-F14S1G4
Membros da 3
Autoria de 7 guias
Um comentário
merci 1000 fois pour ce cite
zmohye - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 1,070
