Ir para o conteúdo principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introdução
Is your Nokia X unable to connect to a USB charger? This guide will shows how to replace a faulty USB port.
Peças
Nenhum componente especificado.
  1. Remove the back cover of the device by applying light pressure toward the outer rim and display.
    • Remove the back cover of the device by applying light pressure toward the outer rim and display.
  2. Remove 7 (size 4 M1 4*3.5) and 4(size 6 M2 6*4.5) screws using P5 hex screwdriver.
    • Remove 7 (size 4 M1 4*3.5) and 4(size 6 M2 6*4.5) screws using P5 hex screwdriver.
    • The M2 screws are shown in red.
    • The M1 screws are shown in orange.
  3. Gently separate the display from the chassis.
    • Gently separate the display from the chassis.
    • Slowly spread the display and chassis until the inside of the device is reachable.
    • Do not pull apart.
    • Using the spudger tool, release the top flex ribbon from the light swap package.
  4. Again, using a spudger tool, release the rear facing camera from the light swap display. Carefully remove the light swap display from the chassis by applying pressure to the circuit board.
    • Again, using a spudger tool, release the rear facing camera from the light swap display.
    • Carefully remove the light swap display from the chassis by applying pressure to the circuit board.
  5. Using a soldering iron, desolder they broken USB port.
    • Using a soldering iron, desolder they broken USB port.
    • Solder your replacement USB port onto the light swap package.
Conclusão
4 outras pessoas concluíram este guia.
Josh Perino
Membro desde: 04-03-2017
394 Reputation
2 Guias de autoria
Equipe
IUPUI, Team S7-G7, Wilson Spring 2017 Membro de IUPUI, Team S7-G7, Wilson Spring 2017
IUPUI-WILSON-S17S7G7
3 Membros
5 Guias de autoria
Adicione um comentário
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 16
All Time: 789
