Ir para o conteúdo principal
Nokia N900 USB Replacement
O que você precisa
  1. Nokia N900 USB Replacement, USB: passo 1, imagem 1 %32
    • Turn the phone over so the screen is face down.
  2. Nokia N900 USB Replacement: passo 2, imagem 1 %32 Nokia N900 USB Replacement: passo 2, imagem 2 %32
    • Remove the back cover by locating the slit on the bottom of the phone and lifting up.
  3. Nokia N900 USB Replacement: passo 3, imagem 1 %32
    • Remove the battery by lifting it out of the device.
  4. Nokia N900 USB Replacement: passo 4, imagem 1 %32 Nokia N900 USB Replacement: passo 4, imagem 2 %32
    • Remove the two "L-shaped" antennas by unscrewing the following screws:
    • Four screw M1 .4x5.0
    • Two screw RF1 .4x4
    • In addition to unscrewing the screws, remove the B-Cover (which will fall right out without the screws).
  5. Nokia N900 USB Replacement: passo 5, imagem 1 %32
    • You will now have two halves of the phone.
    • Grab the half of the phone that has the keyboard on it
  6. Nokia N900 USB Replacement: passo 6, imagem 1 %32
    • Remove the keyboard by unsnapping the frame and then lifting the pad out from the device.
    • Place the key pad and cover to the side for the remaining steps.
  7. Nokia N900 USB Replacement: passo 7, imagem 1 %32
    • Use a blue plastic opening tool lift the motherboard out of the back cover
  8. Nokia N900 USB Replacement: passo 8, imagem 1 %32
    • Look at the bottom of the motherboard to find the:
    • USB Port
    • Once you've located the USB Port you can search online or call the manufacturer to replace it.
Conclusão
3 outras pessoas executaram este guia.
Troy Posey
Membro desde: 03/13/14
349 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 26
Duração total: 2,596
