Ir para o conteúdo principal
Nokia N900 Slider Assembly Replacement
O que você precisa
  1. Nokia N900 Slider Assembly Replacement, Slider Assembly: passo 1, imagem 1 %32
    • Turn the phone over so the screen is face down.
  2. Nokia N900 Slider Assembly Replacement: passo 2, imagem 1 %32 Nokia N900 Slider Assembly Replacement: passo 2, imagem 2 %32
    • Remove the back cover by locating the slit on the bottom of the phone and lifting up.
  3. Nokia N900 Slider Assembly Replacement: passo 3, imagem 1 %32
    • Remove the battery by lifting it out of the device.
  4. Nokia N900 Slider Assembly Replacement: passo 4, imagem 1 %32 Nokia N900 Slider Assembly Replacement: passo 4, imagem 2 %32
    • Remove the two "L-shaped" antennas by unscrewing the following screws:
    • Four screw M1 .4x5.0
    • Two screw RF1 .4x4
    • In addition to unscrewing the screws, remove the B-Cover (which will fall right out without the screws).
  5. Nokia N900 Slider Assembly Replacement: passo 5, imagem 1 %32
    • Turn the back of the phone over so the keyboard is face up. You should then have two halves of the phone.
    • To locate the slider, find the "black tape" on the screen half of the phone.
    • Weave the "slider tape" through the orange slot on the keyboard half of the phone.
    • Once you have completed these steps your phone should be able to slide up and down with ease.
Conclusão
Uma outra pessoa concluiu este guia.
Troy Posey
Membro desde: 03/13/14
349 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 1,029
