Ir para o conteúdo principal
Nokia N900 Slider Assembly Replacement
O que você precisa
  1. Nokia N900 Slider Assembly Replacement, Slider Assembly: passo 1, imagem 1 %32
    • Turn the phone over so the screen is face down.
    Pergunte ao FixBot
    Comentar
  2. Nokia N900 Slider Assembly Replacement: passo 2, imagem 1 %32 Nokia N900 Slider Assembly Replacement: passo 2, imagem 2 %32
    • Remove the back cover by locating the slit on the bottom of the phone and lifting up.
    Pergunte ao FixBot
    Comentar
  3. Nokia N900 Slider Assembly Replacement: passo 3, imagem 1 %32
    • Remove the battery by lifting it out of the device.
    Pergunte ao FixBot
    Comentar
  4. Nokia N900 Slider Assembly Replacement: passo 4, imagem 1 %32 Nokia N900 Slider Assembly Replacement: passo 4, imagem 2 %32
    • Remove the two "L-shaped" antennas by unscrewing the following screws:
    • Four screw M1 .4x5.0
    • Two screw RF1 .4x4
    • In addition to unscrewing the screws, remove the B-Cover (which will fall right out without the screws).
    Pergunte ao FixBot
    Comentar
  5. Nokia N900 Slider Assembly Replacement: passo 5, imagem 1 %32
    • Turn the back of the phone over so the keyboard is face up. You should then have two halves of the phone.
    • To locate the slider, find the "black tape" on the screen half of the phone.
    • Weave the "slider tape" through the orange slot on the keyboard half of the phone.
    • Once you have completed these steps your phone should be able to slide up and down with ease.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Troy Posey
Membro desde: 03/13/14
349 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 37
Ao todo: 1,189
