Ir para o conteúdo principal
Nokia N70 Speaker Replacement
O que você precisa
  1. Nokia N70 Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
  2. Nokia N70 Speaker Replacement: passo 2, imagem 1 %32
    • Remove the battery cover by lifting it away from the phone.
  3. Nokia N70 Speaker Replacement: passo 3, imagem 1 %32
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
  4. Nokia N70 Speaker Replacement: passo 4, imagem 1 %32
    • Remove the battery from the phone.
  5. Nokia N70 Speaker Replacement, Keypad: passo 5, imagem 1 %32 Nokia N70 Speaker Replacement, Keypad: passo 5, imagem 2 %32 Nokia N70 Speaker Replacement, Keypad: passo 5, imagem 3 %32
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
  6. Nokia N70 Speaker Replacement: passo 6, imagem 1 %32 Nokia N70 Speaker Replacement: passo 6, imagem 2 %32 Nokia N70 Speaker Replacement: passo 6, imagem 3 %32
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
  7. Nokia N70 Speaker Replacement, Speaker: passo 7, imagem 1 %32 Nokia N70 Speaker Replacement, Speaker: passo 7, imagem 2 %32
    • Use the T6 Torx screwdriver to remove the six 15 mm Torx screws.
  8. Nokia N70 Speaker Replacement: passo 8, imagem 1 %32 Nokia N70 Speaker Replacement: passo 8, imagem 2 %32 Nokia N70 Speaker Replacement: passo 8, imagem 3 %32
    • Lift the bottom edge of the front panel at a 45 degree angle.
    • Remove front panel by slowly pulling it away from the phone at a 45 degree angle.
  9. Nokia N70 Speaker Replacement: passo 9, imagem 1 %32 Nokia N70 Speaker Replacement: passo 9, imagem 2 %32 Nokia N70 Speaker Replacement: passo 9, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Locate the speaker location located on the back panel of the phone.
    • Using the tweezers place one side of tweezers in the rectangular slot where the speaker is located
    • Slowly lift speaker away from the back panel.
Conclusão
Justin
Membro desde: 10/12/11
984 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 6-2, Regan Fall 2011 Membro de Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 4,113
