Ir para o conteúdo principal
Nokia Lumia 930 Screen Replacement
O que você precisa
  1. Nokia Lumia 930 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Pull the SIM card holder out of the top of the phone using your fingernail.
  2. Nokia Lumia 930 Screen Replacement: passo 2, imagem 1 %32 Nokia Lumia 930 Screen Replacement: passo 2, imagem 2 %32
    • Place tweezers or an opening tool in the SIM card slot and push upwards until the back panel pops out.
  3. Nokia Lumia 930 Screen Replacement: passo 3, imagem 1 %32 Nokia Lumia 930 Screen Replacement: passo 3, imagem 2 %32
    • Wedge a plastic opening tool between the two panels. Slide it along each side of the phone to completely remove the back panel.
  4. Nokia Lumia 930 Screen Replacement: passo 4, imagem 1 %32
    • Remove the 4mm Torx #4 screw that's securing the battery connector.
  5. Nokia Lumia 930 Screen Replacement: passo 5, imagem 1 %32
    • Use tweezers to remove the battery connector strap.
  6. Nokia Lumia 930 Screen Replacement: passo 6, imagem 1 %32 Nokia Lumia 930 Screen Replacement: passo 6, imagem 2 %32
    • Remove all ten 4mm Torx #4 screws that secure the battery cover to the frame of the phone.
  7. Nokia Lumia 930 Screen Replacement: passo 7, imagem 1 %32 Nokia Lumia 930 Screen Replacement: passo 7, imagem 2 %32 Nokia Lumia 930 Screen Replacement: passo 7, imagem 3 %32
    • Use the flat end of a spudger to pry the battery cover from the phone's frame.
  8. Nokia Lumia 930 Screen Replacement: passo 8, imagem 1 %32
    • Pull up on the heat spreader.
    • Be careful not to tear it!
  9. Nokia Lumia 930 Screen Replacement: passo 9, imagem 1 %32
    • Use the flat end of the spudger to lift up the battery.
    • The battery is glued in place. Pry up carefully, not to damage it.
    • Two flex cables are directly underneath the battery.
  10. Nokia Lumia 930 Screen Replacement: passo 10, imagem 1 %32
    • Remove the battery from the phone.
  11. Nokia Lumia 930 Screen Replacement, Motherboard: passo 11, imagem 1 %32 Nokia Lumia 930 Screen Replacement, Motherboard: passo 11, imagem 2 %32
    • Use the flat end of a spudger to disconnect the camera connectors.
    • Pull the camera up and out to remove it from the phone.
  12. Nokia Lumia 930 Screen Replacement: passo 12, imagem 1 %32
    • Use the flat end of a spudger to disconnect the six ribbon cables from the motherboard.
  13. Nokia Lumia 930 Screen Replacement: passo 13, imagem 1 %32 Nokia Lumia 930 Screen Replacement: passo 13, imagem 2 %32 Nokia Lumia 930 Screen Replacement: passo 13, imagem 3 %32
    • Use the flat end of a spudger to pry up the orange flex cable underneath the battery.
    • Remove the orange flex cable from the phone.
  14. Nokia Lumia 930 Screen Replacement: passo 14, imagem 1 %32
    • Repeat the previous step for the black jumper flex cable under the battery.
  15. Nokia Lumia 930 Screen Replacement: passo 15, imagem 1 %32 Nokia Lumia 930 Screen Replacement: passo 15, imagem 2 %32
    • Use the flat end of a spudger to disconnect both ends of the antenna cable from the motherboard.
    • Remove the antenna.
  16. Nokia Lumia 930 Screen Replacement: passo 16, imagem 1 %32
    • Use tweezers to grab the adhesive that is under the LTE flex cable and pull it outwards and towards the bottom end of the phone.
    • Apply new adhesive when reassembling the phone.
  17. Nokia Lumia 930 Screen Replacement: passo 17, imagem 1 %32 Nokia Lumia 930 Screen Replacement: passo 17, imagem 2 %32 Nokia Lumia 930 Screen Replacement: passo 17, imagem 3 %32
    • Use a spudger to pry up the bottom end of the motherboard, then pull it out.
  18. Nokia Lumia 930 Screen Replacement, Daughterboard: passo 18, imagem 1 %32 Nokia Lumia 930 Screen Replacement, Daughterboard: passo 18, imagem 2 %32
    • Use the pointed end of the spudger to pry up the daughterboard.
    • Use tweezers to lift the daughterboard out of the phone.
  19. Nokia Lumia 930 Screen Replacement, Display: passo 19, imagem 1 %32 Nokia Lumia 930 Screen Replacement, Display: passo 19, imagem 2 %32 Nokia Lumia 930 Screen Replacement, Display: passo 19, imagem 3 %32
    • Place a suction cup in the center of the screen, then pry the display away from the frame.
    • When removing the display, pull slowly so that the flex cable does not become damaged.
    • Be sure to fold the display flex cable and ensure it is inserted safely when you are reassembling the display.
    • Remove any adhesive on the display and add new adhesive tape when reassembling the display.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 2,505
