Ir para o conteúdo principal
Nokia Lumia 930 Battery Replacement
O que você precisa
  1. Nokia Lumia 930 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Pull the SIM card holder out of the top of the phone using your fingernail.
  2. Nokia Lumia 930 Battery Replacement: passo 2, imagem 1 %32 Nokia Lumia 930 Battery Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Place tweezers or an opening tool in the SIM card slot and push upwards until the back panel pops out.
  3. Nokia Lumia 930 Battery Replacement: passo 3, imagem 1 %32 Nokia Lumia 930 Battery Replacement: passo 3, imagem 2 %32
    • Wedge a plastic opening tool between the two panels. Slide it along each side of the phone to completely remove the back panel.
  4. Nokia Lumia 930 Battery Replacement: passo 4, imagem 1 %32
    • Remove the 4mm Torx #4 screw that's securing the battery connector.
  5. Nokia Lumia 930 Battery Replacement: passo 5, imagem 1 %32
    • Use tweezers to remove the battery connector strap.
  6. Nokia Lumia 930 Battery Replacement: passo 6, imagem 1 %32 Nokia Lumia 930 Battery Replacement: passo 6, imagem 2 %32
    • Remove all ten 4mm Torx #4 screws that secure the battery cover to the frame of the phone.
  7. Nokia Lumia 930 Battery Replacement: passo 7, imagem 1 %32 Nokia Lumia 930 Battery Replacement: passo 7, imagem 2 %32 Nokia Lumia 930 Battery Replacement: passo 7, imagem 3 %32
    • Use the flat end of a spudger to pry the battery cover from the phone's frame.
  8. Nokia Lumia 930 Battery Replacement: passo 8, imagem 1 %32
    • Pull up on the heat spreader.
    • Be careful not to tear it!
  9. Nokia Lumia 930 Battery Replacement: passo 9, imagem 1 %32
    • Use the flat end of the spudger to lift up the battery.
    • The battery is glued in place. Pry up carefully, not to damage it.
    • Two flex cables are directly underneath the battery.
  10. Nokia Lumia 930 Battery Replacement: passo 10, imagem 1 %32
    • Remove the battery from the phone.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 38
Duração total: 5,792
