Ir para o conteúdo principal
Nokia Lumia 928 Display Assembly Replacement
O que você precisa
  1. Nokia Lumia 928 Display Assembly Replacement, Back Cover: passo 1, imagem 1 %32 Nokia Lumia 928 Display Assembly Replacement, Back Cover: passo 1, imagem 2 %32
    • Power down the phone.
    • There is a screw located inside the 3.5mm headphone jack that needs to be loosened. Use a Torx T5 screwdriver for this.
    • The screw does not come out. Once loosened, It will unlock the lock bar inside the phone. You will break it if you do not complete this step properly.
    • Remove the sim card tray on the top of the phone.
    • Remove the 4.5 mm Torx T5 screw highlighted with a red circle in the picture. (Note: all screws that you will remove in the phone will be the same)
    • There is a sticker located on the screw that needs to be peeled off. This voids your warranty.
  2. Nokia Lumia 928 Display Assembly Replacement: passo 2, imagem 1 %32 Nokia Lumia 928 Display Assembly Replacement: passo 2, imagem 2 %32 Nokia Lumia 928 Display Assembly Replacement: passo 2, imagem 3 %32
    • Using the plastic opening tools, you can start to release the plastic clips around the phone. Start in the top left corner, work your way down the left side. Then do the top and bottom of the phone, and finally the right side.
    • It can be useful to flip the plastic opening tool upside down in certain areas of the phone to make releasing the plastic clips easier.
    • Once all the clips are released, remove the back cover of the phone.
  3. Nokia Lumia 928 Display Assembly Replacement, Motherboard: passo 3, imagem 1 %32
    • Remove all 10 T5 screws on the motherboard. All screws are 4.5 mm Torx T5 screws.
  4. Nokia Lumia 928 Display Assembly Replacement: passo 4, imagem 1 %32 Nokia Lumia 928 Display Assembly Replacement: passo 4, imagem 2 %32
    • Remove the ribbon connector with a highlighted with a red circle with the plastic opening tool.
    • Be very careful with the ribbon connectors as they can easily be ripped off.
    • The ribbon connector highlighted in yellow has a zero insertion force connector. This has a black flap on the end that needs to be flipped up before the ribbon cable can be pulled out.
  5. Nokia Lumia 928 Display Assembly Replacement: passo 5, imagem 1 %32
    • Remove USB port cover using the plastic opening tool, or your hand. It can be removed easily.
  6. Nokia Lumia 928 Display Assembly Replacement: passo 6, imagem 1 %32 Nokia Lumia 928 Display Assembly Replacement: passo 6, imagem 2 %32
    • Pull up the left side of the motherboard.
    • There is 1 connector that needs to be removed with the plastic opening tool highlighted with a red rectangle. Do not pull the motherboard away from the display assembly until you have removed it.
    • You have now removed the motherboard from the display assembly and the back cover.
  7. Nokia Lumia 928 Display Assembly Replacement, Display Assembly: passo 7, imagem 1 %32
    • After following the steps for removing the motherboard, your display assembly can also be removed. These steps happen simultaneously.
    • Again, it's important to be careful in removing the ribbon cable before separating the display from the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Casey
Membro desde: 03/04/16
241 Reputação
Autoria de 2 guias
Equipe
1Comentário do guia
Be carefule in step 4, the red circled connector’s other side is attached by a pair of small plastic hooks to the motherboard. One of the hooks is very small and can be easily bent if that side comes off and has to be reattached.
Martin Doehring - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 21
Ao todo: 1,327
