Ir para o conteúdo principal
Nokia Lumia 925 Front Camera Replacement
O que você precisa
  1. Nokia Lumia 925 Front Camera Replacement, Motherboard: passo 1, imagem 1 %32 Nokia Lumia 925 Front Camera Replacement, Motherboard: passo 1, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the sim card holder by inserting tweezers into the hole. Push down and the holder will spring back up.
    • Pull out the holder until it is completely separate.
    • Something like a paperclip will work if there are no tweezers available.
  2. Nokia Lumia 925 Front Camera Replacement: passo 2, imagem 1 %32 Nokia Lumia 925 Front Camera Replacement: passo 2, imagem 2 %32 Nokia Lumia 925 Front Camera Replacement: passo 2, imagem 3 %32
    • Slide a plastic opening tool under the back cover.
    • Slide the tool around the outsides of the cover to fully dislodge the pins holding the cover to the phone.
    • Some pins are facing the opposite way from the others.
  3. Nokia Lumia 925 Front Camera Replacement: passo 3, imagem 1 %32 Nokia Lumia 925 Front Camera Replacement: passo 3, imagem 2 %32 Nokia Lumia 925 Front Camera Replacement: passo 3, imagem 3 %32
    • Remove the 3 screws using the T7 Torx screwdriver.
    • Unclip the black tab connector.
  4. Nokia Lumia 925 Front Camera Replacement: passo 4, imagem 1 %32 Nokia Lumia 925 Front Camera Replacement: passo 4, imagem 2 %32
    • Remove the silver metal cover.
    • Be careful of the tape under the right square side of the panel. Using a spudger helps.
  5. Nokia Lumia 925 Front Camera Replacement: passo 5, imagem 1 %32 Nokia Lumia 925 Front Camera Replacement: passo 5, imagem 2 %32 Nokia Lumia 925 Front Camera Replacement: passo 5, imagem 3 %32
    • Unclip the two orange tabs.
    • Remove the four silver screws using the T5 Torx screwdriver.
  6. Nokia Lumia 925 Front Camera Replacement: passo 6, imagem 1 %32 Nokia Lumia 925 Front Camera Replacement: passo 6, imagem 2 %32
    • Remove the motherboard by sliding tweezers between it and the back of the screen. Lift up.
  7. Nokia Lumia 925 Front Camera Replacement, Display: passo 7, imagem 1 %32 Nokia Lumia 925 Front Camera Replacement, Display: passo 7, imagem 2 %32
    • Push the screen from the inside of the phone.
    • Pull the screen off.
    • Slide the electronic strip through the small opening.
  8. Nokia Lumia 925 Front Camera Replacement, Speaker: passo 8, imagem 1 %32
    Comprar
    • Locate the grey speaker/camera cover.
    • Carefully remove the cover with either a pair of tweezers or your fingers.
  9. Nokia Lumia 925 Front Camera Replacement: passo 9, imagem 1 %32 Nokia Lumia 925 Front Camera Replacement: passo 9, imagem 2 %32 Nokia Lumia 925 Front Camera Replacement: passo 9, imagem 3 %32
    • With a pair of tweezers, gently remove the orange colored tab closest to the speaker.
  10. Nokia Lumia 925 Front Camera Replacement, Front Camera: passo 10, imagem 1 %32
    • Pull at the orange section until it becomes loose.
    • It is located in the upper leftmost section of the phone behind the front camera.
  11. Nokia Lumia 925 Front Camera Replacement: passo 11, imagem 1 %32
    • Pull vertically on the same orange section until the front camera comes out.
    • The front camera as well as the speaker may come out after the last step so be careful.
Conclusão
O'Ryan Lacour
Membro desde: 09/18/18
85 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 213
