Ir para o conteúdo principal
Nokia Lumia 900 Front Camera Replacement
O que você precisa
  1. Nokia Lumia 900 Front Camera Replacement, Screen: passo 1, imagem 1 %32 Nokia Lumia 900 Front Camera Replacement, Screen: passo 1, imagem 2 %32
    • Insert the pointed end of the spudger into the sim card port indicated by the picture. Then proceed to remove the sim card port entirely.
  2. Nokia Lumia 900 Front Camera Replacement: passo 2, imagem 1 %32 Nokia Lumia 900 Front Camera Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to remove the small rod in the port indicated in the picture.
  3. Nokia Lumia 900 Front Camera Replacement: passo 3, imagem 1 %32 Nokia Lumia 900 Front Camera Replacement: passo 3, imagem 2 %32
    • Separate the screen from the motherboard by prying it open with the spudger along with pulling upwards with the suction cup.
  4. Nokia Lumia 900 Front Camera Replacement: passo 4, imagem 1 %32 Nokia Lumia 900 Front Camera Replacement: passo 4, imagem 2 %32
    • Gently pull apart the screen from the motherboard, with only the ribbons connected from the motherboard to the screen.
  5. Nokia Lumia 900 Front Camera Replacement: passo 5, imagem 1 %32
    • Disconnect the No-fuss cables from the motherboard by gently prying them up using the flat end of the black stick spudger. Make sure not to bend or crease the cable.
    • Remove the screen.
  6. Nokia Lumia 900 Front Camera Replacement, Front Camera: passo 6, imagem 1 %32 Nokia Lumia 900 Front Camera Replacement, Front Camera: passo 6, imagem 2 %32
    • Use the iFixit iOpener or another heat source to gently heat the top left corner until the adhesive under the camera softens.
    • Use the plastic opening tools to carefully lift the front camera from the motherboard.
Conclusão
Kourtney Collier
Membro desde: 03/31/22
289 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 3-2, Harley Spring 2022 Membro de IUPUI, Team 3-2, Harley Spring 2022
IUPUI-HARLEY-S22S3G2
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 114
