Introdução
This component may need to be replaced if you experience a lack of sound during calls.
O que você precisa
Place the phone with the screen facing down.
Remove the back cover by placing your fingernail or plastic opening tool under the slotted indent at the bottom of the phone.
Use the plastic opening tool to push into the slots holding the backing in place.
All five slots are along the inner wall of the battery compartment. Push the slots on the sides first before pushing the slot on the top.
Remove the backing from the frame, making sure to lift the bottom portion away from the phone, to allow the top to slide out of place.
There are five flex connectors located on the motherboard. They look like rectangular metal boxes with a thin strip connected to them.
Unclip the connectors from the motherboard using the plastic opening tool. Lightly press the wedge end of the tool to the opposite site of the connector with the strip attached to it, and pry it up.
Place the plastic opening tool underneath the motherboard near where the three prongs stick out of the bottom and push the motherboard up to remove it.
The headphone jack is located at the top of the phone. It is flush up against a circular hole in the frame of the device.
The speaker is located at the top of the device to the right of the headphone jack.
