Introdução
Please read the entire guide before beginning! Most components in this phone are not user replaceable, as they are soldered directly to the logic board. The few that are replaceable will be removed, or at least pointed out in this guide. I am not responsible for any damage your device may incur.
O que você precisa
Hold the top of the phone's frame between your fingers, and gently apply pressure on the back of the LCD assembly. Do not use too much force. Move your thumbs around to apply pressure at various points.
When viewed from the front, the top left corner of the screen will usually be the first to pop loose.
Run a plastic opening tool or a thumbnail along the top of the screen to free it from the frame assembly.
5 outras pessoas executaram este guia.
3 comentários
Dear,
With many thanks to you. I am interested in connect with you.
Thanks
Your missing prob the thing that breaks most on this phone the usb power supply replacement .
With respect, you’re missing the point of this guide. It’s basic disassembly. The USB port is soldered to the motherboard and is not replaceable by the average person.
