Ir para o conteúdo principal
Nokia Lumia 720 Main and Front Cameras Replacement
O que você precisa
Vídeo de Apresentação
  1. Nokia Lumia 720 Main and Front Cameras Replacement, BATTERY COVER - PART 1: passo 1, imagem 1 %32 Nokia Lumia 720 Main and Front Cameras Replacement, BATTERY COVER - PART 1: passo 1, imagem 2 %32 Nokia Lumia 720 Main and Front Cameras Replacement, BATTERY COVER - PART 1: passo 1, imagem 3 %32
    • Remove the SIM card tray and the memory card try.
    • Use a screwdriver Torx T2 and remove the screw under the SIM card tray.
    • Use plastic tools and start the separating the back cover from the top side.
  2. Nokia Lumia 720 Main and Front Cameras Replacement, BATTERY COVER - PART 2: passo 2, imagem 1 %32 Nokia Lumia 720 Main and Front Cameras Replacement, BATTERY COVER - PART 2: passo 2, imagem 2 %32 Nokia Lumia 720 Main and Front Cameras Replacement, BATTERY COVER - PART 2: passo 2, imagem 3 %32
    • Be careful with the volume buttons.
  3. Nokia Lumia 720 Main and Front Cameras Replacement, Loudspeaker & Antenna module: passo 3, imagem 1 %32 Nokia Lumia 720 Main and Front Cameras Replacement, Loudspeaker & Antenna module: passo 3, imagem 2 %32 Nokia Lumia 720 Main and Front Cameras Replacement, Loudspeaker & Antenna module: passo 3, imagem 3 %32
    • Remove the 3x Torx T4 screws.
    • Buzzer / Loudspeacker
  4. Nokia Lumia 720 Main and Front Cameras Replacement, BATTERY: passo 4, imagem 1 %32 Nokia Lumia 720 Main and Front Cameras Replacement, BATTERY: passo 4, imagem 2 %32 Nokia Lumia 720 Main and Front Cameras Replacement, BATTERY: passo 4, imagem 3 %32
    • Disconnect the battery flex cable.
    • Unstick the metal foil from the logic board.
    • Use a plastic tool with a thin tip and unstuck the battery from the middle frame.
    • Battery - BP-4GWA, 2000mAh, 3.7V, 7.4Vh
  5. Nokia Lumia 720 Main and Front Cameras Replacement, COAXIAL ANTENNA CABLE: passo 5, imagem 1 %32 Nokia Lumia 720 Main and Front Cameras Replacement, COAXIAL ANTENNA CABLE: passo 5, imagem 2 %32 Nokia Lumia 720 Main and Front Cameras Replacement, COAXIAL ANTENNA CABLE: passo 5, imagem 3 %32
    • Disconnect the Antenna cable from the Logic board and from the Charging Dock board and remove it.
  6. Nokia Lumia 720 Main and Front Cameras Replacement, Logic Board: passo 6, imagem 1 %32 Nokia Lumia 720 Main and Front Cameras Replacement, Logic Board: passo 6, imagem 2 %32 Nokia Lumia 720 Main and Front Cameras Replacement, Logic Board: passo 6, imagem 3 %32
    • Disconnect the Volume, Power and camera buttons flex cable.
    • Remove the 4x Torx T4 screws.
    • Slightly lift the board
    • Slowly and gently unstuck the light sensor from the middle frame.
  7. Nokia Lumia 720 Main and Front Cameras Replacement: passo 7, imagem 1 %32 Nokia Lumia 720 Main and Front Cameras Replacement: passo 7, imagem 2 %32 Nokia Lumia 720 Main and Front Cameras Replacement: passo 7, imagem 3 %32
    • Disconnect the Display Assembly flex cable.
    • Disconnect the Charging Dock Board flex cable.
    • Remove the Main board.
  8. Nokia Lumia 720 Main and Front Cameras Replacement, CAMERAS: passo 8, imagem 1 %32 Nokia Lumia 720 Main and Front Cameras Replacement, CAMERAS: passo 8, imagem 2 %32
    • Front Camera with a proximity light sensor.
    • Main / Rear Camera.
Conclusão
ZFix
Membro desde: 12/09/13
194.093 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
327 Membros
Autoria de 1.699 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 1,060
