Ir para o conteúdo principal
Nokia Lumia 635 Motherboard Replacement
O que você precisa
  1. Nokia Lumia 635 Motherboard Replacement, Battery Removal: passo 1, imagem 1 %32 Nokia Lumia 635 Motherboard Replacement, Battery Removal: passo 1, imagem 2 %32
    • Open the back case of the phone using the plastic opening tool.
    • Remove the battery.
  2. Nokia Lumia 635 Motherboard Replacement, Screw Removal: passo 2, imagem 1 %32 Nokia Lumia 635 Motherboard Replacement, Screw Removal: passo 2, imagem 2 %32
    • Remove the five screws shown in the photo using the torx Screwdriver 5mm.
    • Turn your phone sideways and you will find two more screws that you will need to remove using the Torx Screwdriver 5mm.
  3. Nokia Lumia 635 Motherboard Replacement, Remove Hidden Screw: passo 3, imagem 1 %32
    • Remove the black sticker on the bottom left side (As shown in the picture).
    • Remove the screw that was under the black sticker using the Torx Screwdriver 5mm.
  4. Nokia Lumia 635 Motherboard Replacement, Separating Back Cover From Screen: passo 4, imagem 1 %32
    • Using the plastic opening tool separate the plastic cover from the screen.
    • On the top left corner you will see the screens flex cable attached to the mother board, watch out when separating them.
  5. Nokia Lumia 635 Motherboard Replacement, Motherboard Replacement: passo 5, imagem 1 %32 Nokia Lumia 635 Motherboard Replacement, Motherboard Replacement: passo 5, imagem 2 %32 Nokia Lumia 635 Motherboard Replacement, Motherboard Replacement: passo 5, imagem 3 %32
    • Carefully retrieve the camera and audio jack’s flex that is attached to the mother board as shown in the picture.
    • Retrieve the burnt Mother Board and replace it with the new one.
Conclusão
14 outras pessoas executaram este guia.
Daniel Robles
Membro desde: 10/07/14
828 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 7-1, Leahy Fall 2014 Membro de USF Tampa, Team 7-1, Leahy Fall 2014
USFT-LEAHY-F14S7G1
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 16
Últimos 30 dias: 56
Ao todo: 9,485
