Ir para o conteúdo principal
Nokia Lumia 635 Headphone Jack Replacement
O que você precisa
  1. Nokia Lumia 635 Headphone Jack Replacement, Battery Removal: passo 1, imagem 1 %32 Nokia Lumia 635 Headphone Jack Replacement, Battery Removal: passo 1, imagem 2 %32
    • Open the back case of the phone using the plastic opening tool.
    • Remove the battery.
  2. Nokia Lumia 635 Headphone Jack Replacement, Screw Removal: passo 2, imagem 1 %32 Nokia Lumia 635 Headphone Jack Replacement, Screw Removal: passo 2, imagem 2 %32
    • Remove the six screws shown in the photo using the torx Screwdriver 5mm.
    • Turn your phone sideways and you will find two more screws that you will need to remove using the Torx Screwdriver 5mm.
  3. Nokia Lumia 635 Headphone Jack Replacement, Remove Hidden Screw: passo 3, imagem 1 %32 Nokia Lumia 635 Headphone Jack Replacement, Remove Hidden Screw: passo 3, imagem 2 %32
    • Remove the black sticker on the bottom left side (As shown in the picture).
    • Remove the screw that was under the black sticker using the Torx Screwdriver 5mm.
  4. Nokia Lumia 635 Headphone Jack Replacement, Separating Back Cover From Screen: passo 4, imagem 1 %32
    • Using the plastic opening tool separate the plastic cover from the screen.
    • On the top left corner you will see the screens flex attached to the mother bothered, watch out when separating them.
  5. Nokia Lumia 635 Headphone Jack Replacement, Audio Jack Replacement: passo 5, imagem 1 %32
    • Carefully retrieve the audio jack’s flex that is attached to the mother board as shown in the picture.
    • Attach the new audio jack’s flex to the mother board.
Conclusão
3 outras pessoas executaram este guia.
Benjamin
Membro desde: 10/07/14
173 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 7-1, Leahy Fall 2014 Membro de USF Tampa, Team 7-1, Leahy Fall 2014
USFT-LEAHY-F14S7G1
4 Membros
Autoria de 16 guias
1Comentário do guia
where can you buy the headphone jack?
fERD - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 32
Ao todo: 5,160
