Ir para o conteúdo principal
Nokia Lumia 635 Display Assembly Replacement
O que você precisa
Vídeo de Apresentação
  1. Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: passo 1, imagem 1 %32 Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: passo 1, imagem 2 %32 Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: passo 1, imagem 3 %32
    • Switch off the phone.
    • Remove the battery and any installed SIM and memory cards.
    • Remove the black tape near to the loudspeaker.
  2. Nokia Lumia 635 Display Assembly Replacement, SCREWS: passo 2, imagem 1 %32 Nokia Lumia 635 Display Assembly Replacement, SCREWS: passo 2, imagem 2 %32 Nokia Lumia 635 Display Assembly Replacement, SCREWS: passo 2, imagem 3 %32
    • Remove the 9x Torx T4 screws.
    • Two of them are with the same head size but with a different length.
  3. Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: passo 3, imagem 1 %32 Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: passo 3, imagem 2 %32 Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: passo 3, imagem 3 %32
    • Use a plastic opening tool to remove the back cover.
    • Careful unhook the display assembly flex cable.
  4. Nokia Lumia 635 Display Assembly Replacement, TESTING THE NEW SPARE PART: passo 4, imagem 1 %32 Nokia Lumia 635 Display Assembly Replacement, TESTING THE NEW SPARE PART: passo 4, imagem 2 %32 Nokia Lumia 635 Display Assembly Replacement, TESTING THE NEW SPARE PART: passo 4, imagem 3 %32
    • Insert wisdom here.
  5. Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 1: passo 5, imagem 1 %32 Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 1: passo 5, imagem 2 %32
    • Put some scotch tape to prevent the glass from scattering.
    • Use a hot gun or hair dryer and warm the glass to soften the adhesive.
  6. Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: passo 6, imagem 1 %32 Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: passo 6, imagem 2 %32 Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: passo 6, imagem 3 %32
    • Start the separating from the upper right corner, where you have an hole in the middle frame.
    • Use plastic tool to prevent the middle frame from scratches.
    • Work slowly, you can cut your fingers.
  7. Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: passo 7, imagem 1 %32 Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: passo 7, imagem 2 %32 Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: passo 7, imagem 3 %32
    • Clean the middle farme.
    • Put adhesive tape 3MM.
    • Be careful, don't cover the technological openings on the middle frame (for the light sensor, earpiece, etc.).
    • It's easier if you order the spare part together with an adhesive tape.
    • Install the display assembly.
  8. Nokia Lumia 635 Display Assembly Replacement: passo 8, imagem 1 %32 Nokia Lumia 635 Display Assembly Replacement: passo 8, imagem 2 %32
    • That's all.
    • Did you do it successfully?
Conclusão
5 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
197.078 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
333 Membros
Autoria de 1.477 guias
2Comentários do guia
Exactly what I needed! Step by step detailed instructions along with what tools I would need. Heating it up took longer than expected & it took me longer than 30 min, but I actually set aside 2 hours to replace my screen. Woohoo I finally I have a new screen & I did it all on my own...well with the amazing help from ZFix ;D
beatriz_ibre - Responder Compartilhar
how to fix the display
Roneil Mcintosh - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 24
Últimos 30 dias: 66
Ao todo: 10,458
