Ir para o conteúdo principal
Nokia Lumia 635, 630 - Hard Reset
Vídeo de Apresentação
  1. Nokia Lumia 635, 630 - Hard Reset, Nokia Lumia 635, 630 - Hard Reset: passo 1, imagem 1 %32 Nokia Lumia 635, 630 - Hard Reset, Nokia Lumia 635, 630 - Hard Reset: passo 1, imagem 2 %32 Nokia Lumia 635, 630 - Hard Reset, Nokia Lumia 635, 630 - Hard Reset: passo 1, imagem 3 %32
    • Turn the phone off.
    • Press and hold the power button. When the phone vibrates, release it and press and hold the volume down button until you see the exclamation mark on the screen.
    • Another way to do this - press and hold the volume down button and connect the charger.
    • Whit the exclamation mark on the screen press this sequence of keys:
    • -> Volume Up
    • -> Volume Down
    • -> Power button
    • -> Volume Down
    Mine won't go to ! It keeps rebooting to Nokia
    Trillix Wolfie - Responder
    My phone ignores the sequence. It was set up as a child phone, and there’s no “reset phone” button in the about menu. It in fact doesn’t even have the about menu. And trying to reset it using buttons, I get exclamation mark, and once I push the Volume Up button, it starts to boot normally and ignores the rest.
    Sergey Kofanov - Responder
    THanks its a useful ways it works on my phone…nice one
    Abasi Kadewele - Responder
    thank you it worked on my phone!!! I’m very glad! Thank you again!
    szabo_istvan78 - Responder
    When I turn on my Lumia 635, it displays "Nokia" and goes off then comes on again and only display Nokia. After resetting it, it continues the same
    Frank Inyiama - Responder
    my lumia phone was switch off showing Nokia sign in every 10 seconds. after hard reset , it is showing charging sign. what to do next .
    flora - Responder
    Thank you, it worked on my phone. I’m very happy now
    Arham Jahangir - Responder
    Works perfectly,
    thanks.
    And just a note for everyone, TAKE YOUR SD CARD OUT FIRST!!!!! IT WILL WIPE THE DATA!!!!
    Austin Wilson - Responder
    Worked perfectly thank you for this info!!
    jessiecrego83 - Responder
    non riesco a resettare il mio lumia, sarà perchè il sistema operativo è stato aggiornato con il 10?
    qualcuno può suggerirmi qualcosa?
    rosario marchica - Responder
Conclusão
63 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.368 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 321
Autoria de 1.468 guias
32 comentários
Hey, I have done it on the computer, reload the windows but still I get the exclamanition, also the battery is death right now and I don't know how its gonna charge?
remzicanakile - Responder
Phone get rain water, I want to mention it.It opens dont problenm but that sign (!) gonna drive me mad!!
Will this delete contact numbers
suryansh - Responder
Yes if you have the numbers stored somewhere not on the phone then you just have to re add them
Abigail Hard -
will my number still be there and is the phone still active, Do I need to have it reactivated??
or should i take out the sim card first??
robcamp1963 - Responder
Now would I bypass a reset protection notification
STUDENT James Chapman - Responder
its work tnk u... : )
chandanso37 - Responder
It worked for me....thanks a whole lot.....am happy
Christian smart -
Its very Useful... Thank you.... -:)
Madhu K - Responder
It didn't work now I have a sad face on the screen and phone won't cut on
Monicia - Responder
me too it does not work! and why ?
queeniebautista - Responder
It works.. Thanksss... :)
syedhuzaifa96 - Responder
Thanks a million. It worked and a huge problem solved. Thanks again.
Ibrahim Nisar - Responder
When I turn on my Lumia 630, it displays "Nokia" and goes off then comes on again and only display Nokia....will this method bring it back to normal?
Christian smart - Responder
Mine is the same too. I don't know what to do
Frank Inyiama -
It worked... thanks a bunch
It's not working, I repeated the process multiple times and I keep getting the same outcome, it just goes to the Nokia screen, and boots up the same
Anthony Martin - Responder
I have done it but still facing the same problem. The problem is that my sister has given me Nokia Lumia 635 and it is having a problem of ‘This device is locked to a specific mobile operator. Contact your mobile operator for the unlock code.
Beal Geesus - Responder
This method always had worked for me.
Manheche Baptista - Responder
This method always really worked for me.
thank you very much. the method is really superb
sssebyongaabdulnoor - Responder
Not work for me. Hardware reset done. anyway thanks for the details.
Pabodha Lankathilaka - Responder
There is a sad face and the phone won't start
Henry Ncube - Responder
Phone shows a sad face and will not open
the phone loads up to a blue screen then says complete and also says below it if you'd like to know more you can search online later or this and onto of that it says 0% then error.0xc00002e3
carlos gonzalez - Responder
It’s doesn’t work!
Sophia Parsons - Responder
how on god’s green earth are you going to do this “to reassemble your device follow this backward” bro, it’s a Fudging factory reset, not a dissasembaly
alexgamertheminer - Responder
Hallo, ich habe noch ein altes Nokia RM 974 in grün. Ich habe einen Hard-Reset durchgeführt. Nach den beiden Zahnrädern kommt aber leider nur ein ablehnendes und es resettet neu, und alles wiederholt sich. Haben Sie dafür eine Lösung?
Ralf Hader - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 37
Últimos 30 dias: 220
Duração total: 238,154
