Ir para o conteúdo principal
Nokia Lumia 620 Volume and Power Button Replacement
O que você precisa
  1. Nokia Lumia 620 Volume and Power Button Replacement, Volume and Power Button: passo 1, imagem 1 %32
    • Check condition of switches on logicboard
    • Rule out failure of cover
  2. Nokia Lumia 620 Volume and Power Button Replacement: passo 2, imagem 1 %32
    • Torx 6 screwdriver
    • Soldering iron (thin tip)
    • Decent quality solder (thin wire)
  3. Nokia Lumia 620 Volume and Power Button Replacement: passo 3, imagem 1 %32
    • Remove cover, battery and SIM
    • Remove 6 torx screws
    • Note: Green is fine thread
    • Note: Red is coarse thread
  4. Nokia Lumia 620 Volume and Power Button Replacement: passo 4, imagem 1 %32 Nokia Lumia 620 Volume and Power Button Replacement: passo 4, imagem 2 %32
    • Remove plastic clover near battery
    • Keep track of all parts
  5. Nokia Lumia 620 Volume and Power Button Replacement: passo 5, imagem 1 %32
    • Gently release logicboard connectors
  6. Nokia Lumia 620 Volume and Power Button Replacement, Remove logic board: passo 6, imagem 1 %32 Nokia Lumia 620 Volume and Power Button Replacement, Remove logic board: passo 6, imagem 2 %32
    • There is a clip that needs to be moved out of the way before the board will move.
    • Start by lifting long side of logicboard
    • Gently wiggle and lift
    • Undo plastic clips near battery with force
  7. Nokia Lumia 620 Volume and Power Button Replacement: passo 7, imagem 1 %32
    • Check connections of failed buttons
  8. Nokia Lumia 620 Volume and Power Button Replacement: passo 8, imagem 1 %32
    • Resolder broken connections
    • Make sure the pads do not short
  9. Nokia Lumia 620 Volume and Power Button Replacement: passo 9, imagem 1 %32
    • Put back logicboard
    • Make sure pins near camera line-up
    • Note: Plastic clips need quite some force
  10. Nokia Lumia 620 Volume and Power Button Replacement: passo 10, imagem 1 %32
    • Reconnect logicboard connectors
  11. Nokia Lumia 620 Volume and Power Button Replacement: passo 11, imagem 1 %32
    • Put back plastic cover
  12. Nokia Lumia 620 Volume and Power Button Replacement: passo 12, imagem 1 %32
    • Gently tighten screws
    • Put back SIM card and battery
    • Close cover
    • Enjoy the result ;)
Linha de Chegada
11 outras pessoas executaram este guia.
Anne
Membro desde: 10/17/14
456 Reputação
Autoria de 1 guia
4Comentários do guia
Realmente funcionó el tutorial, sirven de nuevo los dos botones que fallaban.
Gaia501 - Responder
Only the 2 middle screws are fine threaded. And you can see in the pictures here, that there are 4 coarse threaded ones and 2 fine threaded ones. The green one in the corner should be red
shadow118 - Responder
hafıza kart okuyucu çalışmıyor ne yapmam lazım
davutcigir - Responder
Omg it looks complicated
Maz Hanvey - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 10,258
