Introdução
With this guide we will help you, if you want to disassemble the phone and replace the Digitizer / Glass or the LCD Display. Also this guide is useful for replacing Loudspeaker, Earpiece, Front camera, etc.
Before ordering the new Touch screen check the revision (you can see it on the digitizer flex cable, near to the connector).
__________________________ Video manual: __________________________
O que você precisa
Vídeo de Apresentação
Switch off the phone, remove the battery and SIM (Memory) card.
The lower back cover is held by 3x T4 Torx screws.
Loudspeaker
Touch screen flex cable connector
LCD Display flex cable connector
If you want to replace the Digitizer, let's test the spare part first.
13 outras pessoas executaram este guia.
2 comentários
i am purchase urgent
