Ir para o conteúdo principal
Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement
O que você precisa
Vídeo de Apresentação
  1. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement, Touch screen / Digitizer, LCD Display: passo 1, imagem 1 %32 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement, Touch screen / Digitizer, LCD Display: passo 1, imagem 2 %32
    • Switch off the phone and remove the battery.
  2. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 2, imagem 1 %32 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 2, imagem 2 %32 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 2, imagem 3 %32
    • Remove 8x Torx T5 screws.
    • With a plastic tool, start with separating the middle frame from the down side.
  3. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 3, imagem 1 %32 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 3, imagem 2 %32
    • The Loudspeaker is on the middle frame.
    • Disconnect the LCD Display flex cable.
    • Disconnect the Touch screen flex cable.
  4. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 4, imagem 1 %32 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 4, imagem 2 %32 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 4, imagem 3 %32
    • The Logic board is held by 2x locking clips at the bottom side.
    • Release it and gently remove it from the front frame.
  5. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 5, imagem 1 %32 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 5, imagem 2 %32 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 5, imagem 3 %32
    • Put tape on the glass to not scatter pieces.
    • Worm the glass to melt the adhesive.
    • Use plastic tools to separate the touchscreen from the frame.
  6. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 6, imagem 1 %32 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 6, imagem 2 %32 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 6, imagem 3 %32
    • After separating, clean up the sticker that remains on the borders.
    • New line.Install the new touchscreen and reassemble the device.
  7. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 7, imagem 1 %32
    • That's all.
    • Did you do it successfully?
Conclusão
4 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
194.147 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
326 Membros
Autoria de 1.672 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 29
Ao todo: 1,968
