Ir para o conteúdo principal
Nokia Lumia 521 SIM Card Replacement
O que você precisa
  1. Nokia Lumia 521 SIM Card Replacement, Battery: passo 1, imagem 1 %32 Nokia Lumia 521 SIM Card Replacement, Battery: passo 1, imagem 2 %32
    • Push the plastic opening tool in between the screen and the back case of the phone.
    • Pry the top of the phone between the case and screen until they are separated.
  2. Nokia Lumia 521 SIM Card Replacement: passo 2, imagem 1 %32
    • Once the cover has been removed, the battery will be visible. Grab the plastic tab and pull it to remove the battery from its place. If there is no plastic tab, use the plastic opening tool to pry the battery loose.
  3. Nokia Lumia 521 SIM Card Replacement, SIM Card: passo 3, imagem 1 %32
    • After the battery is removed, push the SIM card from the left side with your thumb until it is loose.
Conclusão
Marko Stanisic
Membro desde: 02/10/16
322 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 2-4, Sullivan Spring 2016 Membro de USF Tampa, Team 2-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G4
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 1,513
