Ir para o conteúdo principal
Nokia Lumia 520 Touchscreen Replacement
  1. Nokia Lumia 520 Touchscreen  Replacement, Touchscreen and LCD: passo 1, imagem 1 %32
    • Remove the back cover.
  2. Nokia Lumia 520 Touchscreen  Replacement: passo 2, imagem 1 %32
    • Remove the battery.
  3. Nokia Lumia 520 Touchscreen  Replacement: passo 3, imagem 1 %32
    • Remove 5 long screws, pink arrow
    • Remove 3 short screws, blue arrow
  4. Nokia Lumia 520 Touchscreen  Replacement: passo 4, imagem 1 %32 Nokia Lumia 520 Touchscreen  Replacement: passo 4, imagem 2 %32
    • With a thin tool, unhook the central body from the back cover, along the entire profile of the phone
  5. Nokia Lumia 520 Touchscreen  Replacement: passo 5, imagem 1 %32 Nokia Lumia 520 Touchscreen  Replacement: passo 5, imagem 2 %32 Nokia Lumia 520 Touchscreen  Replacement: passo 5, imagem 3 %32
    • Unclip the touchscreen connector
    • Unhook the display connector
    • Unhook the motherboard from the central phone body
  6. Nokia Lumia 520 Touchscreen  Replacement: passo 6, imagem 1 %32 Nokia Lumia 520 Touchscreen  Replacement: passo 6, imagem 2 %32
    • Pull up the central frame from the touchscreen assembly by lifting the clips on the perimeter with a thin tool.
  7. Nokia Lumia 520 Touchscreen  Replacement: passo 7, imagem 1 %32
    • Remove the light sensor from the old frame with the help of a heat source.
    • Insert the sensor in the new frame.
  8. Nokia Lumia 520 Touchscreen  Replacement: passo 8, imagem 1 %32 Nokia Lumia 520 Touchscreen  Replacement: passo 8, imagem 2 %32 Nokia Lumia 520 Touchscreen  Replacement: passo 8, imagem 3 %32
    • Remove film that protects double-sided adhesive from the new touchscreen glass
    • Insert flat touchscreen into the frame slot and adhere the double sided adhesive to the frame by placing it in the correct position
Conclusão
To reassemble the device, follow these instructions in reverse order.
5 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
it en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Smilzo
Membro desde: 11/09/13
11.267 Reputação
Autoria de 39 guias
Um comentário
Can the phone reboot with a gone touch screen?
amar harihar - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 14
Duração total: 1,298
