Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Switch off the phone and remove any SIM and memory card.
Use a plastic tool to separate the back case.
Loudspeaker / Ringer
Disconnect the Touchscreen and the LCD display flex cables.
The logic board is held by tho locking clips. Use plastic tools to remove it.
Light proximity sensor
Earpiece
Audio jack connector
Again use a plastic tool to separate the middle frame and the digitizer frame.
This step is for those who wants to change the LCD display.
Use a sharp object to pick up a little the display.
Then with a spudger or a similar tool separate the display from the frame.
Put some transparent tape on the broken glass.
Use hot air to warm and soften the old adhesive tape.
Start the separating from the middle, where the contact area is small.
Clean the frame
Clean the frame from the adhesive tape remnants and install a new one if your replacement part has come without adhesive tape.
Install the new touch screen and start with reassembling.
That's all.
Did you do it successfully?
12 outras pessoas executaram este guia.
Um comentário
Toughees Telecom the most perfect place for <b>Lumia Screen Repair</b>
You don’t need to worry because we are with you at every step of <a href="http://www.tougheestelecom.in/nokia-lumi... title="Nokia Lumia Repair in Delhi">Lumia screen repair in Delhi</a>, as we understand what one feels when a customer has his <b>Screen Broken or Damaged</b>. You can call us and we will give you the best advice regarding <b>Lumia Screen Repair</b> in Delhi.
