Ir para o conteúdo principal
Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement
O que você precisa
Vídeo de Apresentação
  1. Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement, Touch screen Glass, LCD Display, Loudspeaker, Earpiece: passo 1, imagem 1 %32 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement, Touch screen Glass, LCD Display, Loudspeaker, Earpiece: passo 1, imagem 2 %32 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement, Touch screen Glass, LCD Display, Loudspeaker, Earpiece: passo 1, imagem 3 %32
    • Switch off the phone and remove any SIM and memory card.
    • There are two tips T4 screws.
  2. Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: passo 2, imagem 1 %32 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: passo 2, imagem 2 %32
    • Use a plastic tool to separate the back case.
    • Loudspeaker / Ringer
  3. Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: passo 3, imagem 1 %32 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: passo 3, imagem 2 %32 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: passo 3, imagem 3 %32
    • Disconnect the Touchscreen and the LCD display flex cables.
    • The logic board is held by tho locking clips. Use plastic tools to remove it.
  4. Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: passo 4, imagem 1 %32
    • Light proximity sensor
    • Earpiece
    • Audio jack connector
  5. Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: passo 5, imagem 1 %32 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: passo 5, imagem 2 %32 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: passo 5, imagem 3 %32
    • Again use a plastic tool to separate the middle frame and the digitizer frame.
  6. Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: passo 6, imagem 1 %32 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: passo 6, imagem 2 %32 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: passo 6, imagem 3 %32
    • This step is for those who wants to change the LCD display.
    • Use a sharp object to pick up a little the display.
    • Then with a spudger or a similar tool separate the display from the frame.
  7. Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: passo 7, imagem 1 %32 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: passo 7, imagem 2 %32 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: passo 7, imagem 3 %32
    • Put some transparent tape on the broken glass.
    • Use hot air to warm and soften the old adhesive tape.
    • Start the separating from the middle, where the contact area is small.
  8. Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: passo 8, imagem 1 %32 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: passo 8, imagem 2 %32 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: passo 8, imagem 3 %32
    • Clean the frame
    • Clean the frame from the adhesive tape remnants and install a new one if your replacement part has come without adhesive tape.
    • Install the new touch screen and start with reassembling.
  9. Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: passo 9, imagem 1 %32
    • That's all.
    • Did you do it successfully?
Conclusão
12 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.308 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.535 guias
Um comentário
Toughees Telecom the most perfect place for <b>Lumia Screen Repair</b>
You don’t need to worry because we are with you at every step of <a href="http://www.tougheestelecom.in/nokia-lumi... title="Nokia Lumia Repair in Delhi">Lumia screen repair in Delhi</a>, as we understand what one feels when a customer has his <b>Screen Broken or Damaged</b>. You can call us and we will give you the best advice regarding <b>Lumia Screen Repair</b> in Delhi.
Sachin Seth - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 7,500
