Introdução
Battery draining quickly? It may be time for a new one. Use this guide to help you replace your phone's battery.
O que você precisa
Insert the spudger into the crevice located between the back cover of the phone and the body of the phone.
2 comentários
First off you don t need any tools to open this device, secondly you may damage the sim board in section 2 of this tutorial.There is a ) at the bottom of thephone to easily remove the battery.Use your fingers to gently push open the cover at the corners of the phone changing battery takes 1 minte.
