Ir para o conteúdo principal
Nokia Lumia 520 Battery Replacement
O que você precisa
  1. Nokia Lumia 520 Battery Replacement, Battery: passo 1, imagem 1 %32 Nokia Lumia 520 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Insert the spudger into the crevice located between the back cover of the phone and the body of the phone.
  2. Nokia Lumia 520 Battery Replacement: passo 2, imagem 1 %32 Nokia Lumia 520 Battery Replacement: passo 2, imagem 2 %32
    • Lift the spudger gently to open the back cover of the phone.
  3. Nokia Lumia 520 Battery Replacement: passo 3, imagem 1 %32 Nokia Lumia 520 Battery Replacement: passo 3, imagem 2 %32
    • Insert the spudger into the space between the batter and the battery holder to remove the battery.
Conclusão
Kobina Faibille
Membro desde: 11/03/15
156 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 1-5, Bhusal Fall 2015 Membro de UMass Dartmouth, Team 1-5, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G5
Membros da 3
Autoria de 8 guias
2 comentários
First off you don t need any tools to open this device, secondly you may damage the sim board in section 2 of this tutorial.There is a ) at the bottom of thephone to easily remove the battery.Use your fingers to gently push open the cover at the corners of the phone changing battery takes 1 minte.
beerwings1776 - Responder
Greetings I have a Lumia & I need the Screen and Battery,so how can I get those 2?
Ayoba - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 39
Duração total: 3,662
