Ir para o conteúdo principal
Nokia Lumia 520 Audio Jack Replacement
O que você precisa
  1. Nokia Lumia 520 Audio Jack Replacement, Battery: passo 1, imagem 1 %32 Nokia Lumia 520 Audio Jack Replacement, Battery: passo 1, imagem 2 %32
    • Insert the spudger into the crevice located between the back cover of the phone and the body of the phone.
  2. Nokia Lumia 520 Audio Jack Replacement: passo 2, imagem 1 %32 Nokia Lumia 520 Audio Jack Replacement: passo 2, imagem 2 %32
    • Lift the spudger gently to open the back cover of the phone.
  3. Nokia Lumia 520 Audio Jack Replacement: passo 3, imagem 1 %32 Nokia Lumia 520 Audio Jack Replacement: passo 3, imagem 2 %32
    • Insert the spudger into the space between the batter and the battery holder to remove the battery.
  4. Nokia Lumia 520 Audio Jack Replacement, Audio Jack: passo 4, imagem 1 %32 Nokia Lumia 520 Audio Jack Replacement, Audio Jack: passo 4, imagem 2 %32 Nokia Lumia 520 Audio Jack Replacement, Audio Jack: passo 4, imagem 3 %32
    • Unscrew the 8 screws with a Torx screw driver (T4) and make sure you know what screws went where because they are different.
  5. Nokia Lumia 520 Audio Jack Replacement: passo 5, imagem 1 %32 Nokia Lumia 520 Audio Jack Replacement: passo 5, imagem 2 %32
    • Use your plastic spudger to remove the clips on the plastic casing over the motherboard. Note there are 10 clips holding the casing on(3 on the sides, 2 on the top and bottom).
  6. Nokia Lumia 520 Audio Jack Replacement: passo 6, imagem 1 %32 Nokia Lumia 520 Audio Jack Replacement: passo 6, imagem 2 %32
    • Carefully unclip the digitizer touch screen cable and the display screen cable using the spudger.
  7. Nokia Lumia 520 Audio Jack Replacement: passo 7, imagem 1 %32 Nokia Lumia 520 Audio Jack Replacement: passo 7, imagem 2 %32
    • Gently remove the motherboard.
  8. Nokia Lumia 520 Audio Jack Replacement: passo 8, imagem 1 %32 Nokia Lumia 520 Audio Jack Replacement: passo 8, imagem 2 %32
    • Use the plastic spudger and gently remove the audio jack and the flex connector to the audio jack away from the case.
    • You will feel some pressure since the audio jack is held in place with two sided tape.
Conclusão
5 outras pessoas executaram este guia.
Tyler Chellis
Membro desde: 11/03/15
249 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 1-5, Bhusal Fall 2015 Membro de UMass Dartmouth, Team 1-5, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G5
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 20
Duração total: 2,650
