Introdução
You need a T5 screwdriver to remove the screws.
Peças
Não são necessárias peças.
  1. In order to remove the back cover, you must press the indicated button.
    • In order to remove the back cover, you must press the indicated button.
  2. With the button pressed, apply light pressure and slide the back cover off.
    • With the button pressed, apply light pressure and slide the back cover off.
    • This will allow you to access the battery
    • In order to remove the battery, pull it out from the same side that the rubber button is on.
    • Using a plastic opening tool, separate the back cover from the phone.
    • Continue along the edge with the plastic opening tool.
    • Gently, remove the back cover.
    • Unscrew the indicated screws using the T5 screwdriver.
    • Open the phone up and use the plastic opening tool to remove the cover to the keyboard.
    • Be careful not to break the plastic during this step; do your best not to force anything.
    • The button board will be loose once the cover is removed.
    • Lift it up to reveal the sensor board.
    • With the T5 Screwdriver, remove the marked screws.
    • With the screws removed, the sensor board should be free to flip up.
    • Disconnect the wire with the plastic opening tool.
    • Remove the screws marked.
    • The Screw on the left is located underneath the cable.
    • With those screws removed, the circuit board and sensor board will be detached from the rest of the phone.
Conclusão
4 outras pessoas concluíram este guia.
Cameron Weinberg
498 reputação
6 Guides authored
Equipe
Cal Poly, Team 18-21, Garner Spring 2011 Membro de Cal Poly, Team 18-21, Garner Spring 2011
CPSU-GARNER-S11S18G21
3 Membros
7 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 17
Todo: 5,466
