Ir para o conteúdo principal
Nokia E71x Camera Flash Replacement
O que você precisa
  1. Nokia E71x Camera Flash Replacement, Motherboard: passo 1, imagem 1 %32 Nokia E71x Camera Flash Replacement, Motherboard: passo 1, imagem 2 %32
    • Remove battery
    Pergunte ao FixBot
    Comentar
  2. Nokia E71x Camera Flash Replacement: passo 2, imagem 1 %32
    • Using Torx number 4 unscrew the four 0.5mm screws.
    Pergunte ao FixBot
    Comentar
  3. Nokia E71x Camera Flash Replacement: passo 3, imagem 1 %32
    • Push in four clips to detach the body.
    Pergunte ao FixBot
    Comentar
  4. Nokia E71x Camera Flash Replacement: passo 4, imagem 1 %32 Nokia E71x Camera Flash Replacement: passo 4, imagem 2 %32 Nokia E71x Camera Flash Replacement: passo 4, imagem 3 %32
    • Separate the body into two pieces.
    • Be careful not to damage the screen or body. Some force will be needed to separate the body.
    Pergunte ao FixBot
    Comentar
  5. Nokia E71x Camera Flash Replacement: passo 5, imagem 1 %32 Nokia E71x Camera Flash Replacement: passo 5, imagem 2 %32 Nokia E71x Camera Flash Replacement: passo 5, imagem 3 %32
    • Remove the bottom piece that is clipped on.
    • Some force will need to be exerted to remove the clip.
    Pergunte ao FixBot
    Comentar
  6. Nokia E71x Camera Flash Replacement: passo 6, imagem 1 %32
    • Using Torx number 4 unscrew the two 0.7 mm screws at the top of the device.
    Pergunte ao FixBot
    Comentar
  7. Nokia E71x Camera Flash Replacement: passo 7, imagem 1 %32 Nokia E71x Camera Flash Replacement: passo 7, imagem 2 %32
    • Once screws are removed detach back of phone from the motherboard.
    • This will require some force and maneuvering. Be careful not to break phone back or motherboard.
    Pergunte ao FixBot
    Comentar
  8. Nokia E71x Camera Flash Replacement: passo 8, imagem 1 %32
    • Replace motherboard, ensure that replacement has the same serial number.
    Pergunte ao FixBot
    Comentar
  9. Nokia E71x Camera Flash Replacement, Camera Flash: passo 9, imagem 1 %32
    • Camera is located on back of camera body.
    • To remove flash turn body over and gently tap on the case. The flash should fall out.
    Pergunte ao FixBot
    Comentar
Conclusão
Will Goldby
Membro desde: 08/29/11
187 Reputação
Autoria de 4 guias
Equipe
Cuesta, Team 1-1, Zipperian Fall 2011 Membro de Cuesta, Team 1-1, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G1
3 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 44
Ao todo: 1,366
