Ir para o conteúdo principal
Nokia E62 Complete Disassembly
O que você precisa
  1. Nokia E62 Complete Disassembly, Nokia E62 Complete Disassembly: passo 1, imagem 1 %32
    • To start, press one of the latches at the top of the phone to open the rear cover.
  2. Nokia E62 Complete Disassembly: passo 2, imagem 1 %32
    • Carefully press the other latch.
  3. Nokia E62 Complete Disassembly: passo 3, imagem 1 %32
    • Open rear cover by this side.
  4. Nokia E62 Complete Disassembly: passo 4, imagem 1 %32
    • Press the three latches to open this side of the cover.
  5. Nokia E62 Complete Disassembly: passo 5, imagem 1 %32
    • Remove the rear cover.
  6. Nokia E62 Complete Disassembly: passo 6, imagem 1 %32
    • Removed rear cover. See the latches .
  7. Nokia E62 Complete Disassembly: passo 7, imagem 1 %32
    • Remove the screws using Torx T6 screw driver.
  8. Nokia E62 Complete Disassembly: passo 8, imagem 1 %32
    • Remove six T6 screws.
  9. Nokia E62 Complete Disassembly: passo 9, imagem 1 %32
    • Remove the assembly. The front cover will be released.
  10. Nokia E62 Complete Disassembly: passo 10, imagem 1 %32
    • The front cover released.
  11. Nokia E62 Complete Disassembly: passo 11, imagem 1 %32
    • To remove the display , unscrew the T6 Torx at top.
  12. Nokia E62 Complete Disassembly: passo 12, imagem 1 %32
    • CAUTION! Remove the bottom screw with T5 Torx screw driver, not T6 !
  13. Nokia E62 Complete Disassembly: passo 13, imagem 1 %32
    • Carefully disconnect the Flex cable connector. Then remove the display.
  14. Nokia E62 Complete Disassembly: passo 14, imagem 1 %32
    • Carefully remove the adhesive keyboard membrane.
    • You can replace it at this step if you need to.
  15. Nokia E62 Complete Disassembly: passo 15, imagem 1 %32
    • You can clean the keyboard surface with alcohol, if you dropped a drink here.
  16. Nokia E62 Complete Disassembly: passo 16, imagem 1 %32
    • When you replace the keyboard membrane, align the two contacts at bottom.
  17. Nokia E62 Complete Disassembly: passo 17, imagem 1 %32
    • You can wash the front cover and keyboard if they are dirty.
  18. Nokia E62 Complete Disassembly: passo 18, imagem 1 %32
    • Keyboard - clean it if necessary.
  19. Nokia E62 Complete Disassembly: passo 19, imagem 1 %32
    • Rear side of the circuit board.
  20. Nokia E62 Complete Disassembly: passo 20, imagem 1 %32
    • Speaker and antenna contacts.
  21. Nokia E62 Complete Disassembly: passo 21, imagem 1 %32
    • If necessary, you can replace the joystick, the button module or the connector housing.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 6,962
