Pular para o conteúdo principal
Introdução
This guide will illustrate how to remove the battery in the Nokia E61i.
Ferramentas
Nenhuma ferramenta especificada.
  1. To access the battery you must remove the back cover. Press the tab on the bottom of the cover in so that the back cover plate can slide over it. Now slide the back cover off of the phone.
    • To access the battery you must remove the back cover. Press the tab on the bottom of the cover in so that the back cover plate can slide over it.
    • Now slide the back cover off of the phone.
  2. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Comprar agora
    iPhone X Fix Kits
    Comprar agora
  3. Once the backplate is removed, look to the bottom-left corner of the phone where there is a spot to remove the battery.
    • Once the backplate is removed, look to the bottom-left corner of the phone where there is a spot to remove the battery.
  4. Use your finger to lift the battery out.
    • Use your finger to lift the battery out.
    • The E61i uses a Nokia BP-4L standard battery.
Conclusão
Christopher Patton
Membro desde: 07-04-2011
196 reputação
12 Guias de autoria
Equipe
Cal Poly, Team 9-63, Walters Spring 2011 Membro de Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
5 Membros
12 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Todo: 2,124
