Ir para o conteúdo principal
Nokia Classic 2600c-2b Display Screen Replacement
O que você precisa
  1. Nokia Classic 2600c-2b Display Screen Replacement, Replacing Display Screen: passo 1, imagem 1 %32 Nokia Classic 2600c-2b Display Screen Replacement, Replacing Display Screen: passo 1, imagem 2 %32
    • Press down on the button located at the bottom of the phone, using the center ridge as a guide.
    • Pull the phone apart from the bottom, keeping the button pressed down.
    • CAUTION! The plastic opening tool may be used to gain leverage. Some force is required to open.
  2. Nokia Classic 2600c-2b Display Screen Replacement: passo 2, imagem 1 %32
    • Remove the back cover to expose the battery.
  3. Nokia Classic 2600c-2b Display Screen Replacement: passo 3, imagem 1 %32 Nokia Classic 2600c-2b Display Screen Replacement: passo 3, imagem 2 %32
    • Place a finger or plastic opening tool in the gap between the battery and the phone.
    • Gently lift the battery out.
  4. Nokia Classic 2600c-2b Display Screen Replacement: passo 4, imagem 1 %32 Nokia Classic 2600c-2b Display Screen Replacement: passo 4, imagem 2 %32
    • Locate the plastic latches on the left and right sides of the phone.
    • Insert the plastic opening tool or a fingernail into each latch and pry them open individually.
    • CAUTION! Some force is required.
  5. Nokia Classic 2600c-2b Display Screen Replacement: passo 5, imagem 1 %32
    • Remove the faceplate with the number pad attached.
  6. Nokia Classic 2600c-2b Display Screen Replacement: passo 6, imagem 1 %32
    • Turn the faceplate so the number pad faces downward.
    • Lift the number pad out of the faceplate.
  7. Nokia Classic 2600c-2b Display Screen Replacement: passo 7, imagem 1 %32 Nokia Classic 2600c-2b Display Screen Replacement: passo 7, imagem 2 %32
    • Locate the six screws positions along the edges of the motherboard.
    • Unscrew the six screws using the Torx 5 screwdriver (see Introduction for description of a Torx 5 screwdriver).
    • CAUTION! Place the screws in a secure location.
  8. Nokia Classic 2600c-2b Display Screen Replacement: passo 8, imagem 1 %32 Nokia Classic 2600c-2b Display Screen Replacement: passo 8, imagem 2 %32
    • Locate the orange ribbon tape connecting the metal display plate to the motherboard.
    • Lift the black latch attaching the tape to the motherboard.
    • Gently pull the tape out of the latch slot to remove the metal display.
  9. Nokia Classic 2600c-2b Display Screen Replacement: passo 9, imagem 1 %32 Nokia Classic 2600c-2b Display Screen Replacement: passo 9, imagem 2 %32
    • Using the plastic opening tool, gently pry off the motherboard from the plastic shell.
    • CAUTION! When pulling the motherboard out, be careful not to damage the battery under the lower left hand corner of the motherboard.
  10. Nokia Classic 2600c-2b Display Screen Replacement: passo 10, imagem 1 %32
    • Gently pull the orange ribbon tape up to remove the display.
    • Replace display screen.
    • Follow the instructions in reverse order to reassemble the phone.
Conclusão
Ian VanZandt
Membro desde: 02/14/12
654 Reputação
Autoria de 5 guias
Equipe
James Madison, Team 3-1, Klein Spring 2012 Membro de James Madison, Team 3-1, Klein Spring 2012
JMU-KLEIN-S12S3G1
Membros da 3
Autoria de 9 guias
3 comentários
Pretty accurate, nice guide! Easily repaired and it works!
Dominik Fryč - Responder
Where can I find the screen?
jackie fincher -
Perfect guide! But Where can i get original components??
Navin Singh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 12
Duração total: 948
