Ir para o conteúdo principal
Nokia Asha 201 Screen Replacement
O que você precisa
  1. Nokia Asha 201 Screen Replacement, Screen: passo 1, imagem 1 %32
    • Remove back cover of device by pressing firmly and sliding the cover off.
    Pergunte ao FixBot
    Comentar
  2. Nokia Asha 201 Screen Replacement: passo 2, imagem 1 %32
    • Using your finger, lift up on battery to remove from the device.
    Pergunte ao FixBot
    Comentar
  3. Nokia Asha 201 Screen Replacement: passo 3, imagem 1 %32
    • Using a screwdriver, remove the two screws from the back case.
    Pergunte ao FixBot
    Comentar
  4. Nokia Asha 201 Screen Replacement: passo 4, imagem 1 %32
    • Pry off the front case using a iFixit opening tool.
    Pergunte ao FixBot
    Comentar
  5. Nokia Asha 201 Screen Replacement: passo 5, imagem 1 %32
    • Remove the Keyboard with your hands.
    Pergunte ao FixBot
    Comentar
  6. Nokia Asha 201 Screen Replacement: passo 6, imagem 1 %32
    • Remove the four screws pictured here.
    Pergunte ao FixBot
    Comentar
  7. Nokia Asha 201 Screen Replacement: passo 7, imagem 1 %32
    • Using the iFixit opening tool, separate the screen from motherboard.
    Pergunte ao FixBot
    Comentar
    • Unplug your old screen from your phone, unpack your new one and gently plug in the new screen. Make sure you plug in the screen just like the old one was placed in the phone.
    Pergunte ao FixBot
    Comentar
  8. Nokia Asha 201 Screen Replacement: passo 9, imagem 1 %32
    • After plugging in the new screen put back the screen onto the motherboard.
    Pergunte ao FixBot
    Comentar
  9. Nokia Asha 201 Screen Replacement: passo 10, imagem 1 %32
    • Use a philips #00 screwdriver to put back the four 3.5 mm screws trays pictured here.
    Pergunte ao FixBot
    Comentar
  10. Nokia Asha 201 Screen Replacement: passo 11, imagem 1 %32
    • Using your fingers place the keyboard back like in the picture.
    Pergunte ao FixBot
    Comentar
  11. Nokia Asha 201 Screen Replacement: passo 12, imagem 1 %32
    • Using your fingers and the Phillips opening tool reposition and adjust the front case onto the phone.
    Pergunte ao FixBot
    Comentar
  12. Nokia Asha 201 Screen Replacement: passo 13, imagem 1 %32
    • Using the Phillips #0 screwdriver, screw back in the two screws to the back case.
    Pergunte ao FixBot
    Comentar
  13. Nokia Asha 201 Screen Replacement: passo 14, imagem 1 %32
    • Using your fingers put back the battery in the back of the phone properly.
    Pergunte ao FixBot
    Comentar
  14. Nokia Asha 201 Screen Replacement: passo 15, imagem 1 %32
    • Slide back in the phone cover to the back of the device.
    Pergunte ao FixBot
    Comentar
Conclusão
Replacing Nokia Asha 201 screen takes several steps. These steps should be followed precisely to have the screen replaced without complications. Each step should be done before start doing the next step. After you’re done following these steps, you should start reassembling the device. To reassemble the device, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team S1-G3, Leahy Fall 2019 Membro de USF Tampa, Team S1-G3, Leahy Fall 2019
USFT-LEAHY-F19S1G3
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 33
Ao todo: 882
