Ir para o conteúdo principal
Nokia 8390 Motherboard Replacement
O que você precisa
  1. Nokia 8390 Motherboard Replacement, Back Cover: passo 1, imagem 1 %32
    • Locate the button on the bottom of the back cover.
  2. Nokia 8390 Motherboard Replacement: passo 2, imagem 1 %32 Nokia 8390 Motherboard Replacement: passo 2, imagem 2 %32 Nokia 8390 Motherboard Replacement: passo 2, imagem 3 %32
    • Depress the button with your finger.
    • While the button is depressed, slide the back cover off of the phone.
  3. Nokia 8390 Motherboard Replacement, Outer Case: passo 3, imagem 1 %32 Nokia 8390 Motherboard Replacement, Outer Case: passo 3, imagem 2 %32 Nokia 8390 Motherboard Replacement, Outer Case: passo 3, imagem 3 %32
    • Grasp the top and bottom of the front cover.
    • Grasp the phone body with your other hand.
    • Lightly pull the casing off of the phone.
  4. Nokia 8390 Motherboard Replacement, Keypad: passo 4, imagem 1 %32 Nokia 8390 Motherboard Replacement, Keypad: passo 4, imagem 2 %32 Nokia 8390 Motherboard Replacement, Keypad: passo 4, imagem 3 %32
    • Lightly peel the keypad off of the phone.
  5. Nokia 8390 Motherboard Replacement, Motherboard: passo 5, imagem 1 %32 Nokia 8390 Motherboard Replacement, Motherboard: passo 5, imagem 2 %32 Nokia 8390 Motherboard Replacement, Motherboard: passo 5, imagem 3 %32
    • Locate the six star-shaped screws on the phone.
    • Note: There are two on the bottom end, two in the middle, and two on the top end.
    • Remove these screws using the screwdriver.
  6. Nokia 8390 Motherboard Replacement: passo 6, imagem 1 %32 Nokia 8390 Motherboard Replacement: passo 6, imagem 2 %32 Nokia 8390 Motherboard Replacement: passo 6, imagem 3 %32
    • Grab the top and bottom of the phone casing.
    • Carefully pull the motherboard apart from the bottom casing.
    • The circuit board should be divided into two parts.
  7. Nokia 8390 Motherboard Replacement: passo 7, imagem 1 %32 Nokia 8390 Motherboard Replacement: passo 7, imagem 2 %32 Nokia 8390 Motherboard Replacement: passo 7, imagem 3 %32
    • Grab the top and bottom of the remaining casing.
    • Carefully pull apart the casing from the circuit board.
  8. Nokia 8390 Motherboard Replacement: passo 8, imagem 1 %32
    • The circuit board should be divided into three parts, completely separate from the back casing, as shown.
Conclusão
Clinton
Membro desde: 10/22/12
57 Reputação
Autoria de 7 guias
Equipe
Clemson, Team 14-5, Benson Fall 2012 Membro de Clemson, Team 14-5, Benson Fall 2012
CLEM-BENSON-F12S14G5
3 Membros
Autoria de 21 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 25
Últimos 30 dias: 59
Ao todo: 807
