Introdução
Installing a new vibration component is necessary when the vibrate mode on your phone is no longer functioning properly. Installation requires no prior knowledge of mobile phone vibrators.
O que você precisa
Locate the small button on the top of the phone.
Depress the button.
With your other hand, pull the front cover away from the phone.
Remove all six 5.3 mm long T6 screws.
Remove the circuit board/faceplate sub-assembly from the back of the phone.
