Ir para o conteúdo principal
Nokia 8290 Microphone Replacement
O que você precisa
  1. Nokia 8290 Microphone Replacement, Front Cover: passo 1, imagem 1 %32 Nokia 8290 Microphone Replacement, Front Cover: passo 1, imagem 2 %32 Nokia 8290 Microphone Replacement, Front Cover: passo 1, imagem 3 %32
    • Locate the small button on the top of the phone.
    • Depress the button.
    • With your other hand, pull the front cover away from the phone.
    Pergunte ao FixBot
    Comentar
  2. Nokia 8290 Microphone Replacement, Circuit Board: passo 2, imagem 1 %32 Nokia 8290 Microphone Replacement, Circuit Board: passo 2, imagem 2 %32 Nokia 8290 Microphone Replacement, Circuit Board: passo 2, imagem 3 %32
    • Remove all six 5.3 mm long T6 screws.
    • Remove the circuit board/faceplate sub-assembly from the back of the phone.
    • Take care to place screws in a safe location.
    Pergunte ao FixBot
    Comentar
  3. Nokia 8290 Microphone Replacement: passo 3, imagem 1 %32 Nokia 8290 Microphone Replacement: passo 3, imagem 2 %32 Nokia 8290 Microphone Replacement: passo 3, imagem 3 %32
    • Using your fingers, pull the small plastic tab away from the circuit board/faceplate sub-assembly.
    • Rotate the faceplate away from the circuit board.
    • Gently remove the faceplate from the circuit board, taking care to not break the small plastic tab on the other side of the sub-assembly.
    Pergunte ao FixBot
    Comentar
  4. Nokia 8290 Microphone Replacement, Microphone: passo 4, imagem 1 %32 Nokia 8290 Microphone Replacement, Microphone: passo 4, imagem 2 %32 Nokia 8290 Microphone Replacement, Microphone: passo 4, imagem 3 %32
    • Use the spudger to peel back the top-left corner of the white adhesive film. This can be done by working the spudger back and forth underneath the film.
    Pergunte ao FixBot
    Comentar
  5. Nokia 8290 Microphone Replacement: passo 5, imagem 1 %32 Nokia 8290 Microphone Replacement: passo 5, imagem 2 %32 Nokia 8290 Microphone Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Continue to peel the film back until you can see the microphone.
    • Use tweezers to remove the microphone.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Clemson, Team 15-3, Benson Fall 2012 Membro de Clemson, Team 15-3, Benson Fall 2012
CLEM-BENSON-F12S15G3
3 Membros
Autoria de 22 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 60
Ao todo: 668
