Pular para o conteúdo principal
Introdução
The keypad may need to be replaced if the buttons on your phone are cracked. This guide will only instruct the user on how to replace the keypad interface, but will not actually replace the circuitry that allows the buttons to operate. Such a repair is covered in the Installing Nokia 8290 Circuit Board repair guide.
Ferramentas
Nenhuma ferramenta especificada.
Peças
Nenhum componente especificado.
  1. Locate the small button on the top of the phone. Depress the button. With your other hand, pull the front cover away from the phone.
    • Locate the small button on the top of the phone.
    • Depress the button.
    • With your other hand, pull the front cover away from the phone.
  2. Apple Watch Kits
    Screen and battery repairs just got easier.
    Comprar agora
    Apple Watch Kits
    Comprar agora
  3. After removing the front cover, simply peel the keypad away from the front cover After removing the front cover, simply peel the keypad away from the front cover After removing the front cover, simply peel the keypad away from the front cover
    • After removing the front cover, simply peel the keypad away from the front cover
Conclusão
Austin Culberson
Membro desde: 22-10-2012
78 reputação
5 Guias de autoria
Equipe
Clemson, Team 15-3, Benson Fall 2012 Membro de Clemson, Team 15-3, Benson Fall 2012
CLEM-BENSON-F12S15G3
3 Membros
21 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 264
