Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Installing a new antenna may be necessary if you are having trouble sending and receiving calls. Installation should only be done as a last resort, after trying all other possible solutions as listed in the Nokia 8290 Troubleshooting Guide. Installation requires no prior knowledge of mobile phone antennas.
O que você precisa
Locate the small button on the top of the phone.
Depress the button.
With your other hand, pull the front cover away from the phone.
Remove all six 5.3 mm long T6 screws.
Remove the circuit board/faceplate sub-assembly from the back of the phone.
