Ir para o conteúdo principal
Nokia 8265 Keypad Replacement
O que você precisa
  1. Nokia 8265 Keypad Replacement, Keypad: passo 1, imagem 1 %32
    • Using a plastic opening tool, wedge the tip of the tool into the side of the phone's faceplate
    • To pry open, wiggle/twist the tip of the tool, until faceplate pops up.
  2. Nokia 8265 Keypad Replacement: passo 2, imagem 1 %32
    • Once popped off, remove the faceplate entirely, exposing the keypad.
  3. Nokia 8265 Keypad Replacement: passo 3, imagem 1 %32
    • You can pick up the keypad with ease, as it is not attached to the phone itself.
  4. Nokia 8265 Keypad Replacement: passo 4, imagem 1 %32
    • To clean keypad if it is not functioning properly, use a cloth to wipe away any spills, or water damage
Conclusão
If cleaning off keypad does not work, insert your new keypad, and follow steps in reverse order to reassemble your device.
Jack
Membro desde: 04/20/12
1 Reputação
Autoria de 4 guias
Equipe
SUNY Cortland, Team 1-1, Getto Spring 2012 Membro de SUNY Cortland, Team 1-1, Getto Spring 2012
SUNYCORT-GETTO-S12S1G1
Membros da 2
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 802
