Ir para o conteúdo principal
Nokia 8265 Display Screen/Keyboard Replacement
O que você precisa
  1. Nokia 8265 Display Screen/Keyboard Replacement, Display Screen/Keyboard: passo 1, imagem 1 %32
    • Start by removing the face plate of the phone with a plastic tool.
    • Once plastic tool is wedged into the side of the phone, twist and leverage the face plate off.
  2. Nokia 8265 Display Screen/Keyboard Replacement: passo 2, imagem 1 %32
    • Once the face plate is off, you will have exposed the keypad.
  3. Nokia 8265 Display Screen/Keyboard Replacement: passo 3, imagem 1 %32
    • Simply remove the keypad from on top of the phone, and place it off to the side, leaving just the phone itself remaining
  4. Nokia 8265 Display Screen/Keyboard Replacement: passo 4, imagem 1 %32
    • Taking a very small screwdriver, carefully unscrew the six screws attaching the top layer of the screen from the body of the phone.
    • Make sure to remember what screw goes where.
  5. Nokia 8265 Display Screen/Keyboard Replacement: passo 5, imagem 1 %32
    • Once the six screws are removed, you may take off the screen section of the phone, exposing the inner workings of the cell phone.
  6. Nokia 8265 Display Screen/Keyboard Replacement: passo 6, imagem 1 %32
    • Now you have successfully removed the display screen and keyboard.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Jack
Membro desde: 04/20/12
1 Reputação
Autoria de 4 guias
Equipe
SUNY Cortland, Team 1-1, Getto Spring 2012 Membro de SUNY Cortland, Team 1-1, Getto Spring 2012
SUNYCORT-GETTO-S12S1G1
Membros da 2
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 907
