Ir para o conteúdo principal
Nokia 8260 Microphone Replacement
O que você precisa
  1. Nokia 8260 Microphone Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the cell phone.
    Pergunte ao FixBot
    Comentar
  2. Nokia 8260 Microphone Replacement: passo 2, imagem 1 %32
    • Press down on the round button on the back cover of the phone.
    Pergunte ao FixBot
    Comentar
  3. Nokia 8260 Microphone Replacement: passo 3, imagem 1 %32
    • Slide the back cover down while still pressing the button.
    Pergunte ao FixBot
    Comentar
  4. Nokia 8260 Microphone Replacement: passo 4, imagem 1 %32
    • Remove the back cover.
    Pergunte ao FixBot
    Comentar
  5. Nokia 8260 Microphone Replacement: passo 5, imagem 1 %32
    • Press the end of the battery towards the top of the phone.
    Pergunte ao FixBot
    Comentar
  6. Nokia 8260 Microphone Replacement: passo 6, imagem 1 %32
    • Lift the battery outwards while still pressing it upwards till it pops out.
    • You may need to take several attempts to lift out the battery.
    Pergunte ao FixBot
    Comentar
  7. Nokia 8260 Microphone Replacement, Antenna: passo 7, imagem 1 %32
    • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
    • This step may be a bit difficult if you are removing the antenna for the first time.
    Pergunte ao FixBot
    Comentar
  8. Nokia 8260 Microphone Replacement: passo 8, imagem 1 %32
    • Pry open the antenna door by pulling down the top of the spudger
    Pergunte ao FixBot
    Comentar
  9. Nokia 8260 Microphone Replacement: passo 9, imagem 1 %32
    • Remove the antenna door.
    Pergunte ao FixBot
    Comentar
  10. Nokia 8260 Microphone Replacement: passo 10, imagem 1 %32
    • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
    • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
    • Try to keep the antenna as flat as possible. Do not bend it.
    Pergunte ao FixBot
    Comentar
  11. Nokia 8260 Microphone Replacement, Circuit Board: passo 11, imagem 1 %32
    • Remove the five screws with the Torx Screwdriver: two near the bottom, two in the middle, and one under the antenna door.
    • The two bottom screws are longer than the upper three.
    Pergunte ao FixBot
    Comentar
  12. Nokia 8260 Microphone Replacement: passo 12, imagem 1 %32
    • Remove the back covering.
    Pergunte ao FixBot
    Comentar
  13. Nokia 8260 Microphone Replacement: passo 13, imagem 1 %32
    • Remove the two screws at the top.
    Pergunte ao FixBot
    Comentar
  14. Nokia 8260 Microphone Replacement: passo 14, imagem 1 %32
    • Remove the metal plating and the circuit board.
    • There is nothing holding the rest of the phone together. Handle the rest of the phone carefully.
    • The LCD will be attached to the circuit board.
    Pergunte ao FixBot
    Comentar
  15. Nokia 8260 Microphone Replacement, Keypad: passo 15, imagem 1 %32
    • Remove the plastic border lying on the keypad.
    Pergunte ao FixBot
    Comentar
  16. Nokia 8260 Microphone Replacement: passo 16, imagem 1 %32
    • Remove the keypad.
    • Depending on what you are doing, you can take out or leave the buttons to the keypad in the front casing.
    Pergunte ao FixBot
    Comentar
  17. Nokia 8260 Microphone Replacement, Microphone: passo 17, imagem 1 %32
    • Remove the microphone.
    Pergunte ao FixBot
    Comentar
Conclusão
Aaron Jen
Membro desde: 04/11/10
1 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 27-94, Amido Spring 2010 Membro de Cal Poly, Team 27-94, Amido Spring 2010
CPSU-AMIDO-S10S27G94
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 43
Ao todo: 1,551
