Ir para o conteúdo principal
Nokia 8260 Keypad Replacement
O que você precisa
  1. Nokia 8260 Keypad Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the cell phone.
  2. Nokia 8260 Keypad Replacement: passo 2, imagem 1 %32
    • Press down on the round button on the back cover of the phone.
  3. Nokia 8260 Keypad Replacement: passo 3, imagem 1 %32
    • Slide the back cover down while still pressing the button.
  4. Nokia 8260 Keypad Replacement: passo 4, imagem 1 %32
    • Remove the back cover.
  5. Nokia 8260 Keypad Replacement: passo 5, imagem 1 %32
    • Press the end of the battery towards the top of the phone.
  6. Nokia 8260 Keypad Replacement: passo 6, imagem 1 %32
    • Lift the battery outwards while still pressing it upwards till it pops out.
    • You may need to take several attempts to lift out the battery.
  7. Nokia 8260 Keypad Replacement, Antenna: passo 7, imagem 1 %32
    • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
    • This step may be a bit difficult if you are removing the antenna for the first time.
  8. Nokia 8260 Keypad Replacement: passo 8, imagem 1 %32
    • Pry open the antenna door by pulling down the top of the spudger
  9. Nokia 8260 Keypad Replacement: passo 9, imagem 1 %32
    • Remove the antenna door.
  10. Nokia 8260 Keypad Replacement: passo 10, imagem 1 %32
    • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
    • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
    • Try to keep the antenna as flat as possible. Do not bend it.
  11. Nokia 8260 Keypad Replacement, Circuit Board: passo 11, imagem 1 %32
    • Remove the five screws with the Torx Screwdriver: two near the bottom, two in the middle, and one under the antenna door.
    • The two bottom screws are longer than the upper three.
  12. Nokia 8260 Keypad Replacement: passo 12, imagem 1 %32
    • Remove the back covering.
  13. Nokia 8260 Keypad Replacement: passo 13, imagem 1 %32
    • Remove the two screws at the top.
  14. Nokia 8260 Keypad Replacement: passo 14, imagem 1 %32
    • Remove the metal plating and the circuit board.
    • There is nothing holding the rest of the phone together. Handle the rest of the phone carefully.
    • The LCD will be attached to the circuit board.
  15. Nokia 8260 Keypad Replacement, Keypad: passo 15, imagem 1 %32
    • Remove the plastic border lying on the keypad.
  16. Nokia 8260 Keypad Replacement: passo 16, imagem 1 %32
    • Remove the keypad.
    • Depending on what you are doing, you can take out or leave the buttons to the keypad in the front casing.
Conclusão
Aaron Jen
Membro desde: 04/11/10
1 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 27-94, Amido Spring 2010 Membro de Cal Poly, Team 27-94, Amido Spring 2010
CPSU-AMIDO-S10S27G94
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 15,842
