Ir para o conteúdo principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introdução
How to remove the gold patch antenna.
Peças
Nenhum componente especificado.
  1. Turn off the cell phone.
    • Turn off the cell phone.
  2. Press down on the round button on the back cover of the phone.
    • Press down on the round button on the back cover of the phone.
  3. Slide the back cover down while still pressing the button.
    • Slide the back cover down while still pressing the button.
  4. Remove the back cover.
    • Remove the back cover.
  5. Press the end of the battery towards the top of the phone.
    • Press the end of the battery towards the top of the phone.
  6. Lift the battery outwards while still pressing it upwards till it pops out.
    • Lift the battery outwards while still pressing it upwards till it pops out.
    • You may need to take several attempts to lift out the battery.
  7. Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
    • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
    • This step may be a bit difficult if you are removing the antenna for the first time.
  8. Pry open the antenna door by pulling down the top of the spudger
    • Pry open the antenna door by pulling down the top of the spudger
  9. Remove the antenna door.
    • Remove the antenna door.
  10. If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
    • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
    • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
    • Try to keep the antenna as flat as possible. Do not bend it.
Conclusão
Uma outra pessoa concluiu este guia.
Aaron Jen
Membro desde: 11-04-2010
1 Reputation
7 Guias de autoria
Equipe
Cal Poly, Team 27-94, Amido Spring 2010 Membro de Cal Poly, Team 27-94, Amido Spring 2010
CPSU-AMIDO-S10S27G94
4 Membros
14 Guias de autoria
Adicione um comentário
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,106
