Ir para o conteúdo principal
Nokia 6590i Battery Charger Connector Replacement
O que você precisa
  1. Nokia 6590i Battery Charger Connector Replacement, Battery: passo 1, imagem 1 %32 Nokia 6590i Battery Charger Connector Replacement, Battery: passo 1, imagem 2 %32
    • Press the button on the bottom of the rear cover.
    • Keep the button pressed while pulling the cover downward to remove the back cover.
    • Lift the cover off.
  2. Nokia 6590i Battery Charger Connector Replacement: passo 2, imagem 1 %32
    • To remove the battery, push it down from the top and pull it out.
  3. Nokia 6590i Battery Charger Connector Replacement, Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: passo 3, imagem 1 %32
    • Grip the front cover from the bottom.
  4. Nokia 6590i Battery Charger Connector Replacement: passo 4, imagem 1 %32
    • Lift the front cover off.
  5. Nokia 6590i Battery Charger Connector Replacement: passo 5, imagem 1 %32
    • Remove the six screws using a T6 torx screwdriver.
  6. Nokia 6590i Battery Charger Connector Replacement: passo 6, imagem 1 %32
    • Insert spudger along edge of assembly and gently lift assembly away from case
  7. Nokia 6590i Battery Charger Connector Replacement: passo 7, imagem 1 %32
    • Remove assembly from phone
  8. Nokia 6590i Battery Charger Connector Replacement, Logic Board: passo 8, imagem 1 %32
    • The logic board now sits on top of the phone.
  9. Nokia 6590i Battery Charger Connector Replacement: passo 9, imagem 1 %32
    • Lift the logic board out of the phone.
  10. Nokia 6590i Battery Charger Connector Replacement, Battery Charger Connector: passo 10, imagem 1 %32
    • Locate battery charger connector
  11. Nokia 6590i Battery Charger Connector Replacement: passo 11, imagem 1 %32
    • Grasp top and bottom of battery charger connector on the left side
  12. Nokia 6590i Battery Charger Connector Replacement: passo 12, imagem 1 %32
    • Lift out the battery charger connector
Conclusão
Colby Leslie
Membro desde: 10/05/10
1 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 22-3, Maness Fall 2010 Membro de Cal Poly, Team 22-3, Maness Fall 2010
CPSU-MANESS-F10S22G3
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,886
