Introdução
This guide shows you how to replace the speakers on your Nokia 6560.
O que você precisa
Remove the back cover of your cell phone by pushing the small slider with your fingernail towards the top of the phone.
Lift off your cell phone's back cover.
Open the front cover of your cell phone with the plastic opening tool or finger nail.
Lift the cover upwards, starting from the bottom below the keypad.
Unscrew the six T6 torx screws which attach the frame to the cell phone case.
Use the plastic opening tool to unmount the thin metal frame at the tab connections. You must do this on both sides.
Lift the thin metal frame off of the plastic frame.
Now you have the bare plastic frame that holds the speaker.
The microphone is held at the bottom of this frame.
Neither the speaker nor the microphone can be repaired. You must replace the whole frame.
