Ir para o conteúdo principal
Nokia 6350-1b Display Screen Replacement
O que você precisa
  1. Nokia 6350-1b Display Screen Replacement, Display Screen: passo 1, imagem 1 %32 Nokia 6350-1b Display Screen Replacement, Display Screen: passo 1, imagem 2 %32
    • Using an iFixit opening tool, separate the plastic frame and the rest of the phone.
    • Move the opening tool along the frame, unlocking all of the locks that keep the frame in place.
    • Remove the plastic frame and set aside.
    • Be careful not to pry too hard; doing so could crack the plastic frame.
  2. Nokia 6350-1b Display Screen Replacement: passo 2, imagem 1 %32
    • Using a T-5 screw driver, unscrew the screws on the four corners of the phone.
    • Using an opening tool, pry between the screen cover (top left) and the phone frame (top right).
    • To separate, unlock the various groove-like locks on all four sides of the phone.
    • Carefully remove the screen cover (top left) to reveal the logic board (bottom).
    • Keep track of the four small screws. They will be needed to put the phone back together.
  3. Nokia 6350-1b Display Screen Replacement: passo 3, imagem 1 %32
    • Disconnect the flex cable from the logic board.
    • Disconnect the damaged LCD display screen and remove from the device.
    • Remember to dispose of the damaged LCD display screen responsibly; do not throw away with household trash, as electronic parts are considered household hazardous waste (HHW).
  4. Nokia 6350-1b Display Screen Replacement: passo 4, imagem 1 %32
    • Connect the new LCD display screen to the phone.
    • Reconnect the logic board (bottom right) to the flex cable (gold tab).
  5. Nokia 6350-1b Display Screen Replacement: passo 5, imagem 1 %32
    • Using the T-5 screwdriver, screw the four screws back into the phone.
  6. Nokia 6350-1b Display Screen Replacement: passo 6, imagem 1 %32
    • Place the cover back on the device so that it is in the correct position to be reinstalled. Use the opening tool from earlier to direct the cover with precision.
    • Press gently on the cover so that it snaps back into place.
Conclusão
Uma outra pessoa concluiu este guia.
Anna
Membro desde: 04/13/12
25 Reputação
Autoria de 2 guias
Equipe
SUNY Cortland, Team 1-2, Getto Spring 2012 Membro de SUNY Cortland, Team 1-2, Getto Spring 2012
SUNYCORT-GETTO-S12S1G2
2 Membros
Autoria de 8 guias
1Comentário do guia
Hi
Thanks for putting these together. I have a flip phone 6350 and I love it. Every time one stops functioning I get another one used. But I often have problems with the charging ports. The connection gets wonky and only works when I move the plug around in the socket of the phone. Can these be easily replaced? fixed? I even tried using a universal charger and charged the batteries in that, but then the battery connections stopped working.
thanks!
Annemarie
Annemarie Heineman - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 2,023
