O que você precisa
Press and hold the battery release button and slide the battery away from the Nokia logo
Remove the screw holding the antenna to the circuit board.
Carefully lift off the antenna from the circuit board.
Gently pop out the golden spring in the middle of the speaker. It should come out with little force.
