O que você precisa
Press and hold the battery release button and slide the battery away from the Nokia logo
Unscrew and remove the four T6 Torx screws.
A comment for anyone wanting to clean the metal contacts to improve keypad response, make sure you spray iso alcohol onto a lint free cloth and wipe the contacts, not onto the device itself and definitely not onto the LCD screen, as it can leave a marl on the screen. Luckily it evaporated eventually but only after 48hrs...
Remove the screw holding the antenna to the circuit board.
Carefully lift off the antenna from the circuit board.
Uma outra pessoa concluiu este guia.
