Ir para o conteúdo principal
Nokia 6310i Keypad Replacement
O que você precisa
  1. Nokia 6310i Keypad Replacement, Battery: passo 1, imagem 1 %32 Nokia 6310i Keypad Replacement, Battery: passo 1, imagem 2 %32
    • Press and hold the battery release button and slide the battery away from the Nokia logo
    Pergunte ao FixBot
    Comentar
  2. Nokia 6310i Keypad Replacement, SIM card: passo 2, imagem 1 %32 Nokia 6310i Keypad Replacement, SIM card: passo 2, imagem 2 %32 Nokia 6310i Keypad Replacement, SIM card: passo 2, imagem 3 %32
    • Slide the SIM card lock away from the SIM card.
    • The SIM card pops out. Remove the SIM card.
    Pergunte ao FixBot
    Comentar
  3. Nokia 6310i Keypad Replacement, Back Cover: passo 3, imagem 1 %32
    • Unscrew and remove the four T6 Torx screws.
    Pergunte ao FixBot
    Comentar
  4. Nokia 6310i Keypad Replacement: passo 4, imagem 1 %32 Nokia 6310i Keypad Replacement: passo 4, imagem 2 %32 Nokia 6310i Keypad Replacement: passo 4, imagem 3 %32
    • Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
    Pergunte ao FixBot
    Comentar
  5. Nokia 6310i Keypad Replacement: passo 5, imagem 1 %32 Nokia 6310i Keypad Replacement: passo 5, imagem 2 %32 Nokia 6310i Keypad Replacement: passo 5, imagem 3 %32
    • Use the plastic opening tool to separate the top part of the backplate.
    • The plastic clips at the top require slightly more force to separate.
    Pergunte ao FixBot
    Comentar
  6. Nokia 6310i Keypad Replacement, Antenna: passo 6, imagem 1 %32 Nokia 6310i Keypad Replacement, Antenna: passo 6, imagem 2 %32
    • Remove the screw holding the antenna to the circuit board.
    • Carefully lift off the antenna from the circuit board.
    Pergunte ao FixBot
    Comentar
  7. Nokia 6310i Keypad Replacement, Motherboard: passo 7, imagem 1 %32
    • Lift off the motherboard from the faceplate.
    Pergunte ao FixBot
    Comentar
  8. Nokia 6310i Keypad Replacement, Keypad: passo 8, imagem 1 %32 Nokia 6310i Keypad Replacement, Keypad: passo 8, imagem 2 %32
    • Remove the plastic keypad from the faceplate.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Ka Siu
Membro desde: 09/30/10
84 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 14-41, Forte Fall 2010 Membro de Cal Poly, Team 14-41, Forte Fall 2010
CPSU-FORTE-F10S14G41
5 Membros
Autoria de 22 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 48
Ao todo: 6,037
